    Adding a STATICTEXT element to a Description... changes in C4D 2024?
    2024c++
    10 Posts 3 Posters 2.1k Views 2 Watching
    • fwilleke80F Offline
      fwilleke80
      sometimes I need to add a STATICTEXT element to a Description in GetDDescription(). I have this function that I've been using for many years now, and that works fine in R20 - C4D 2023. However, in C4D 2024, calling it does not do anything.
      maxon::Bool AddStaticText(Description* const description, const DescID* const singleId, const DescID& groupid, const maxon::Int32 id = 0, const maxon::String& name = ""_s)
      	if (!description)
      		return false;
      	const DescID descId = CreateDescID(DescLevel(id, DTYPE_STATICTEXT, 0));
      	if (MAXON_LIKELY(!singleId || id.IsPartOf(*singleId, nullptr)))
      		BaseContainer bc = GetCustomDataTypeDefault(DTYPE_STATICTEXT);
      		bc.SetString(DESC_NAME, name);
      		bc.SetInt32(DESC_ANIMATE, DESC_ANIMATE_OFF);
      		bc.SetBool(DESC_REMOVEABLE, false);
      		return description->SetParameter(descId, bc, groupid);
      	return true;
      I call it like this:
      Bool MyObject::GetDDescription(const GeListNode* node, Description* description, DESCFLAGS_DESC& flags) const
      	if (!node || !description)
      		return false;
      	if (!description->LoadDescription(node->GetType()))
      		return false;
      	flags |= DESCFLAGS_DESC::LOADED;
      	const DescID* const singleid = description->GetSingleDescID();
      	if (!AddStaticText(description, singleid, MYOBJECT_SOMEGROUP))
      		return false;
      	return SUPER::GetDDescription(node, description, flags);
      Why does this not work anymore in C4D 2024?
      www.frankwilleke.de
      Only asking personal code questions here.
        fwilleke80
        Ah, I think I found it already.
        In earlier C4D API versions, it was okay to provide an id value of 0. Since C4D 2024, we have to provide a proper value. Calling my AddStaticText() function with an id other than 0 works.
        www.frankwilleke.de
          ferdinand @fwilleke80
          Hey @fwilleke80,
          Thank you for reaching out to us. Your code looks fine, so I do not see at a glance what is going wrong. Have you stepped through your code, to check how it behaves; does it go into the MAXON_LIKELY, what is the return value of SetParameter?
            @fwilleke80 said in Adding a STATICTEXT element to a Description... changes in C4D 2024?:
            Great to hear! Remember, all IDs up to 1000 in the first DescLevel of a DescID are reserved for Cinema 4D. There is a good chance that you overwrite important data, brick a scene, when you write into that range.
              fwilleke80
              Hi Ferdinand,
              @ferdinand said in Adding a STATICTEXT element to a Description... changes in C4D 2024?:
              Yes, I have. And it does go into the MAXON_LIKELY and SetParameter() does return true.
              Thanks! Yes, I know that. Using IDs far above 1000 πŸ™‚
              So, knowing that STATICTEXT IDs of 0 are not working anymore in C4D 2024, here's a question out of curiosity:
              In .res files, it's common practice to use STATICTEXT {} to fill up empty space, e.g. in a layer layout with columns. What ID values does C4D use for STATICTEXT elements like this?
              Frank
              www.frankwilleke.de
                In .res files, it's common practice to use STATICTEXT {} to fill up empty space, e.g. in a layer with columns. What ID values does C4D use for STATICTEXT elements like this?
                Good question, I will ask Pablo, because I have no idea πŸ™‚
                fwilleke80F 1 Reply Last reply Reply Quote 0
                  fwilleke80 @ferdinand
                  Thanks! And say hello to him from me πŸ™‚
                  www.frankwilleke.de
                  ferdinandF 1 Reply Last reply Reply Quote 1
                  • P Offline
                    pablo
                    Hello Frank! It's wonderful to hear from you! Warm greetings from Spain!
                      Hello @fwilleke80,
                      Pablo found out that such IDs are generated when the description is parsed and elements without an ID get then assigned an ID based on a global variable which is incremented after each usage. You can see its definition below.
                      As you can see, the address space starts out at 2^29. So if you somewhat want to emulate that, you could pick IDs starting out at 2^30 (and would be still well below the overflow threshold of (2^32)/2).
                        fwilleke80
                        Very informative, thank you Ferdinand!
                        www.frankwilleke.de
