    • Unread
    New Child Render settings with python
    Cinema 4D SDK
    2024 python
    1.1k
    • M
      masterofthejack
      I am trying to generate a "new child" of a master render setting in python whilst trying to keep the values in that child to inherit from the parent, however I can only clone or copy the settings which make the values unique and I have to tell the child by hand afterwards to inherit the settings. Is there anyway to create a child in Python that will automatically inherit the masters settings? Here is my code, it generates a take as well and assigns a camera and render dimensions based on the objects name (i.e. Object_3840x2160):
      def show_alert(message):
          dlg = c4d.gui.MessageDialog(message)
          return dlg
          # Get the active Cinema 4D document
          take_data = doc.GetTakeData()
          # Retrieve information about the selected object
          sel_object = doc.GetActiveObject()
          object_name = sel_object.GetName()
          active_object = doc.GetActiveObject()
          # Check if the object name follows the correct format "NAME_WIDTHxHEIGHT"
          name_parts = object_name.split("_")
          if len(name_parts) != 2:
              show_alert("Please make sure the object's name follows the format: NAME_WIDTHxHEIGHT")
          width_height_parts = name_parts[1].split("x")
          if len(width_height_parts) != 2:
          try:
              width = int(width_height_parts[0])
              height = int(width_height_parts[1])
          except ValueError:
              show_alert("Please make sure WIDTH and HEIGHT are whole numbers in the format: NAME_WIDTHxHEIGHT")
          def find_camera_child(obj):
              if not obj:
                  return None
              for child in obj.GetChildren():
                  if child.GetType() == c4d.Ocamera:
                      return child
              return None
          # Find a camera as a child of the active object
          camera_child = find_camera_child(active_object)
          if camera_child:
              print(f"Found camera child: {camera_child.GetName()}")
              print("No camera child found.")
          # Create a new take and set its properties
          new_take = take_data.AddTake("", None, take_data.GetMainTake().GetDown())
          if camera_child:
              new_take.SetCamera(take_data, camera_child)
          take_name = name_parts[0]
          new_take.SetName(take_name)
          # Activate the newly created take and trigger an update
          take_data.SetCurrentTake(new_take)
          # Retrieve active render settings and create new ones
          active_render_settings = doc.GetActiveRenderData()
          #active_render_data = active_render_settings.GetClone
          parent_render_settings = active_render_settings.GetUp() or active_render_settings
          new_render_settings = active_render_settings.GetClone()
          new_render_settings_name = name_parts[0]
          new_render_settings.SetName(new_render_settings_name)
          # Set the resolution width and height in the new render settings
          new_render_settings[c4d.RDATA_XRES] = width
          new_render_settings[c4d.RDATA_YRES] = height
          print(f"Set resolution: {width}x{height}")
          # Insert the new render settings after the last sibling or as the first child
          last_sibling = parent_render_settings.GetDownLast()
          if last_sibling:
              new_render_settings.InsertAfter(last_sibling)
              new_render_settings.InsertUnder(parent_render_settings)
          # Set the new render settings as the active render data and trigger an update
          doc.SetActiveRenderData(new_render_settings)
          new_take.SetRenderData(take_data, new_render_settings)
          c4d.EventAdd(c4d.EVENT_FORCEREDRAW)
      • M
        masterofthejack
        I should mention also that the Object needs a camera as its child also. This setup is specific to a pipeline we are implementing in our studio.
        Thanks
        • ferdinandF
          ferdinand @masterofthejack
          Hello @masterofthejack,
          Although this is your second posting, it is your first thread, so let me welcome you to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!
          Getting Started
          Before creating your next postings, we would recommend making yourself accustomed with our Forum and Support Guidelines, as they line out details about the Maxon SDK Group support procedures. Of special importance are:
          • Support Procedures: Scope of Support: Lines out the things we will do and what we will not do.
          • Support Procedures: Confidential Data: Most questions should be accompanied by code but code cannot always be shared publicly. This section explains how to share code confidentially with Maxon.
          • Forum Structure and Features: Lines out how the forum works.
          • Structure of a Question: Lines out how to ask a good technical question. It is not mandatory to follow this exactly, but you should follow the idea of keeping things short and mentioning your primary question in a clear manner.
          About your First Question
          In short, this functionality is not public and works in general not too well with Python API as it assumes things to happen in a certain order (which the Python API can violate). The cloning behavior is determined by this setting of the parent you clone from:
          When you clone from such parent, you will also clone this setting. It is expressed as a bitflag. The flag is not exposed in the public API (neither Python nor C++) because this is part of the backend behavior of a module. Internally it has the symbol RENDERSETTINGS_BIT_OVERRIDEBEHAVIOUR, and while one can set this flag and emulate other things, the Inherit Override Behavior option is tightly coupled to the Render Settings Menu and we cannot emulate everything it does.
          In practice this can mean that things go out of whack when you just toggle this setting often enough programmatically.
          Result:
          You see there at the end that when I turn the behavior off for a node where we programmatically enabled it, the bitmask of that node goes out of whack, and things aren't anymore as they should be.
          Code:
          """Demonstrates how to toggle the private "Inherit Parent Behavior" flag for a RenderData element.
          Note:
              I would strongly advise against making use of this, as you can potentially corrupt your scenes
              with this. It is extremely unlikely, but not impossible.
          doc: c4d.documents.BaseDocument # The active document.
          # This a non-public bit flag for render settings which controls the "Inherit Parent Behavior"
          # setting of a render data node.
          c4d.RENDERSETTINGS_BIT_OVERRIDEBEHAVIOUR: int = 1 << 6
              # Clone the active render data insert the clone under the parent.
              parent: c4d.RenderData = doc.GetActiveRenderData()
              if not parent:
              clone: c4d.RenderData = parent.GetClone(c4d.COPYFLAGS_NONE)
              clone.InsertUnderLast(parent)
              # Make sure that the "Inherit Parent Behavior" setting is enabled. When #parent had it enabled,
              # we will have cloned that setting anyways, this is just for the case that we want to inherit
              # from a parent which does not have it enabled (but we want the child to have it enabled).
              clone.DelBit(c4d.RENDERSETTINGS_BIT_OVERRIDEBEHAVIOUR)
              clone.SetName(f"{clone.GetName()} (CLONE)")
              # In case we wanted to turn off this behaviour for a clone of a parent which has it enabled, we
              # would have to do this.
              # clone.SetBit(c4d.RENDERSETTINGS_BIT_OVERRIDEBEHAVIOUR)
              # This a bit weird stuff ensures that the inheritance relation does not go out of whack so
              # easily, but we can only emulate what the Render settings implementation is doing internally.
              parent.SetDirty(c4d.DIRTYFLAGS_DATA)
              doc.SetParameter(c4d.DOCUMENT_USERCHANGE, True, (1 << 3))
          • M
            masterofthejack
            Hi @ferdinand
            Thanks so much for your comprehensive reply, very interesting. I couldnt emulate your result, as in the childs behaviour was still unique but I can see trying to do this will be problematic. As this script is built to generate a template to begin with I will just loop a step into our process which dictates to the creator to select all settings inside the children to inherit settings, one cannot completely omit manual tasks but one can try.
            One more problem Im having is camera that is apart of my setup (the camera that is the child of the object Im setting the dimensions with) doesnt update its frustrum or aspect ratio until I manually change the render dimensions in the newly created render settings slightly and return to the value created just to have it update in the veiwport, wonderingif there is some sort of update function I can include to do this.
            I should mention that the camera has some xpresso attached that sets its frustrum to lock onto a plane regardless of its position, I developed it to behave much like an "nDisplay" from Unreal engine. Developing this script was integral for us to quickly set POV per projected space for the purpose of immersive projection content. Thank you for all your help so far, if I could share my setup and scene with you, it might make more sense but I understand this space is probably not meant for that.
            • ferdinandF
              One more problem I am having is camera that is a part of my setup [...] doesn't update its frustum or aspect ratio until I manually change [... the] settings slightly [...] I should mention that the camera has some Xpresso attached [...]
              I have to speculate here a bit, since I do not fully understand what you are doing.
              1. When you change the render data of a document (or change anything else in it), this inherently will flag things as dirty and cause the scene passes to be executed, i.e., stuff to update.
              2. This however does not happen immediately when you run for example the line rdata[c4d.RDATA_XRES] = 42 but when the main loop of Cinema 4D evaluates everything in a scene which is dirty. You can also trigger this yourself manually so that you can benefit early from changes (see below).
              3. c4d.EventAdd() is a necessary component in Script Manager scripts, as things often seemingly 'won't update' . Things actually do update, but the UI does not immediately reflect that without an EventAdd until the user then interacts with the scene (which causes an EventAdd). I would however avoid using EVENT_FORCEREDRAW unless it is really necessary - which seems unlikely here.
              What to do exactly, depends a bit on what you want to do and what your setup is. But in general you seem to run into the problem that the passes are not executed often enough (or at all) on your scene, what we talked about under (2.). You can do this with BaseDocument.ExecutePasses. It usage is quite straight forward, you just run it and things are then updated.
              """Demonstrates how to execute the passes on a document.
              from mxutils import CheckType
                  # Allocate a cube object and a look at camera tag on it.
                  cube: c4d.BaseObject = CheckType(c4d.BaseObject(c4d.Ocube))
                  tag: c4d.BaseTag = CheckType(cube.MakeTag(c4d.Tlookatcamera))
                  doc.InsertObject(cube)
                  c4d.EventAdd() # Meaningless here since the passes have not run #doc.
                  # The cube has no cache at this point, and also the tag did not orient the cube yet.
                  print(f"{cube.GetCache() = }")
                  print(f"{cube.GetMg() = }")
                  # Now we execute the passed on doc, specifically the cache and expression (i.e., tags) pass.
                  doc.ExecutePasses(bt=None, animation=False, expressions=True, caches=True, flags=c4d.BUILDFLAGS_NONE)
                  # Now things are "updated".
                  # What we did here will automatically happen once a Script Manager script ended. There are two
                  # scenarios where one has to execute the passes manually.
                  # 1. We want to make in code use of an updated scene before Cinema 4D on its own executes the
                  #    passes on it to get hold of information such as the cache or matrix here.
                  # 2. Sometimes complex dependencies between scene elements can require passes to be executed
                  #    more than once when we build or update such setups. Three executions in a row should
                  #    suffice even for the most complex setups.
                  # We have a field driven by a tag which is dependent on particle information. We change something
                  # deep down in the dependency relation and want things to update all at once. Note that it is
                  # NOT dependencies == number of executions. Internally, Cinema 4D executes the passes three
                  # times in a row at most. Executing the passes is expensive.
                  # This should wiggle pretty much everything into place.
                  for _ in range(3):
                      doc.ExecutePasses(None, True, True, True, c4d.BUILDFLAGS_NONE)
              • M
                masterofthejack
                Thank you @ferdinand, I'll need to work out how I implement but once again a thorough and considered reply....
                • ferdinandF ferdinand referenced this topic on
