    Cinema 4D Connector is not working on 2023.2.0
    Scheduled Pinned Locked Moved Bugs
    3 Posts 2 Posters 1.2k Views 1 Watching
    • T Offline
      Tng
      As said in the title, Cinema 4D Connector is not loading in 2023.2.0 version. Do you have any ETA for a fix ? I would like to dev on the latest cinema 4d but without the connector it is much more time consuming 😞
      Thanks in advance!
        ferdinand @Tng
        Hey @Tng,
        thank you for reaching out to us. As discussed in Cinema 4D Connector not working on 2023.2.0:
        The plugin you are attempting to use has become superfluous with 2023.2 as the VS Code bindings are now integrated with Cinema 4D. See Cinema 4D 2023.2.0 Release[URL-REMOVED] or Python SDK Change Notes for Cinema 4D 2023.2.
        [URL-REMOVED] @maxon: This section contained a non-resolving link which has been removed.
        • T Offline
          Tng
          Thank you very much for the quick answer, i effectively forgot to look into the changes notes 🙂
          • maxonM maxon moved this topic from Cinema 4D SDK on
