    • Unread
    EnhanceMainMenu Inconsistent results in different c4d versions
    Cinema 4D SDK
    2023 python
    • chuanzhenC
      chuanzhen
      My plug- in is displayed in the window, but the results are different in different versions. The c4d version before S22 is arranged at the end of the window, and the version 2023 is arranged before. The code has not changed.
      pic
      code:
      def EnhanceMainMenu():
          mainMenu = gui.GetMenuResource("M_VIEW_WINDOW")
          pluginsMenu = gui.SearchPluginMenuResource()
          menu = c4d.BaseContainer()
          menu.InsData(c4d.MENURESOURCE_SUBTITLE, "Doodle")            # Set the name of the menu
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1060253") #switch doodle
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1022257") #draw pen
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1022286") #eraser pen
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1022215") #Add empty frame
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1060256")  # active doodle layer
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1060254") #before onion
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1060255") #after onion
          menu.InsData(c4d.MENURESOURCE_SEPERATOR, True);
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1022384") #duplicate doodle
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1022281") #clear doodle
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1022280") #remove doodle
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1060257") #add doodle layer
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_1060258") #top doodle layer
          if pluginsMenu:
              # Insert menu after 'Plugins' menu
              mainMenu.InsDataAfter(c4d.MENURESOURCE_STRING, menu, pluginsMenu)
              # Insert menu after the last existing menu ('Plugins' menu was not found)
              mainMenu.InsData(c4d.MENURESOURCE_STRING, menu)
      Thanks for any help!
      相信我,可以的!
      • i_mazlovI
        i_mazlov
        Hi @chuanzhen,
        Thank you for reaching out to us. The gui.SearchPluginMenuResource() function is searching for the category in the M_EDITOR menu. When working with any other menu (e.g. M_VIEW_WINDOW in your exact case), it doesn't make any sense trying to insert custom menu after it (because it points out to a category in a completely different menu).
        Hence the following code will be giving consistent results in both S22 and R2023:
        Ilia
        chuanzhenC 1 Reply Last reply Reply Quote 1
        • chuanzhenC
          chuanzhen @i_mazlov
          @i_mazlov Thanks
          相信我,可以的!
