    Checking for ALT GetInputState() issue
    python2023
    6 Posts 2 Posters 1.4k Views 1 Watching
    • P Offline
      pim
      I have a command plugin with a slider to move the distance between planes.
      If the user presses ALT and move the slider, I update the position of place realtime.
      Input and ALT checking is done with below code.
      Checking for ALT is oke, but when there is no parent and a message is given to the user, it looks like the GetInputState() is still running and the slider is moved.
      How can I 'stop' the GetInputState() in case of an error?
      I hope I make myself clear.
      if (id == UI_SPACING):
                  self.Spacing  = self.GetInt32(UI_SPACING)
                  msg=c4d.BaseContainer()
                  if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD,c4d.KEY_ALT, msg):
                      if msg[c4d.BFM_INPUT_VALUE]:    # only dynamic update if Alt is pressed
                          parent = doc.GetActiveObject()
                          if (not(parent)):
                              gui.MessageDialog('Please select a cloner!')
                              self.DoHorizontalSpacing(parent, self.Spacing)
      • M Online
        m_adam
        Hi @pim sorry I was busy the last days, regarding your question keep in mind that returning true cancel all others messages so please forward the message at the end so all operations like drag operation are performed correctly.
        1 week ago the question on How to detect CTRL being pressed in a GeDialog was asked, and the correct way is to check for BFM_INPUT_QUALIFIER and not BFM_INPUT_VALUE
        If it does not work, then I will ask you to provide a complete example.
        P 1 Reply Last reply Reply Quote 0
        • P Offline
          pim @m_adam
          @m_adam
          Thanks for replying.
          Let me first of all explain in a bit more detail, what happens.
          I have a input field that is handle in Command().
          I test for ALT input, in which case I want to space some planes.
          Before I space the planes, I test for a selected object.
          If not, then I give out an error message.
          However, after giving out the error message, the input field is still active, so when I move the cursor, the input value is changed and I cannot select an object.
          I must click the input field first before I can select.
          I also noticed from your example that you check Alt in Message() and not in Command().
          Here the code.
          from c4d import plugins, gui, documents, bitmaps
          import c4d, os
          PLUGINSTRING = "Alt test"
          PLUGIN_ID = 105284244
          UI_SPACING              = 15048
          class AltTestDialog(c4d.gui.GeDialog):
              def CreateLayout(self):
                  self.SetTitle(PLUGINSTRING)
                  self.AddStaticText(id=1001, flags=c4d.BFH_MASK, initw=150, name="Spacing", borderstyle=c4d.BORDER_NONE)
                  self.AddEditSlider(UI_SPACING, c4d.BFH_SCALEFIT, initw=80, inith=0)
              def Command(self, id, msg):
                  doc = documents.GetActiveDocument()
                              if (not(parent)):
                                  #self.DoHorizontalSpacing(parent, self.Spacing)
                                  pass
          class AltTest(c4d.plugins.CommandData):
              dialog = None
              def Init(self, op):
              def Message(self, type, data):
              def Execute(self, doc):
                  if self.dialog is None:
                      self.dialog = AltTestDialog()
                  return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=400, defaulth=160)
              bmp = c4d.bitmaps.BaseBitmap()
              dir, file = os.path.split(__file__)
              fn = os.path.join(dir, "res", "Icon.tif")
              bmp.InitWith(fn)
              okyn = plugins.RegisterCommandPlugin(PLUGIN_ID, PLUGINSTRING, 0, bmp, PLUGINSTRING, AltTest())
              if (okyn):
                  print (PLUGINSTRING + " initialized.")
                  print ("Error initializing " + PLUGINSTRING )
          • M Online
            m_adam
            Hi thanks a lot, I'm now able to reproduce the issue, this may take some time (if this is even possible) to provide a workaround. But will for sure find a way to achieve that within this week.
            • M Online
              m_adam
              Just checked with development team, and this is a bug as this is something we don't really support and the slider having a default behavior for when alt is currently executed. So far there is no workaround, so the best way to proceed would be to create your own alert windows like so:
              UI_SPACING = 15048
              class AlertDialog(c4d.gui.GeDialog):
                  @staticmethod
                  def Create(msg):
                      alertDlg = AlertDialog(msg)
                      alertDlg.Open(c4d.DLG_TYPE_MODAL, defaultw=0, defaulth=0)
                      return alertDlg
                  def __init__(self, msg):
                      self.message = msg
                      self.AddStaticText(id=1000, flags=c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, initw=150, name=self.message)
                      self.AddDlgGroup(c4d.DLG_OK)
                  def Command(self, messageId, bc):
                      if messageId == c4d.DLG_OK:
                          self.Close()
                  def Command(self, gadgetId, msg):
                      if gadgetId == UI_SPACING:
                          newMsg = c4d.BaseContainer()
                          if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD,c4d.KEY_ALT, newMsg):
                              if newMsg[c4d.BFM_INPUT_VALUE]:    # only dynamic update if Alt is pressed
                                  if not parent:
                                      AlertDialog.Create('Please select a cloner!')
                  global dlg
                  # Creates a new instance of the GeDialog
                  dlg = AltTestDialog()
                  # Opens the GeDialog, since it's open it as Modal, it block Cinema 4D
                  dlg.Open(c4d.DLG_TYPE_ASYNC, defaultw=300, defaulth=50)
              Maxime
              • P Offline
                pim
                Great, thank you
                Glad I can help to improve this great program.
                • P pim referenced this topic on
