    • Unread
    Assignment Grouped
    Cinema 4D SDK
    r21
    • W
      WDP
      How can I use Python to select the sub-objects for a color assignment for grouped objects zero objects?
      • ferdinandF
        Hello @WDP,
        thank you for reaching out to us. Unfortunately your question is not clear for me. I assume you want to retrieve all children of a null object, so that you can add a material to them (to change their diffuse color)?
        It would be best if you could clarify your question. I have posted however an example for what seems likely to be your goal.
        The result:
        The code:
        """Simple example for iterating over direct children and creating materials.
        To be run in the script manger.
        As discussed in:
            plugincafe.maxon.net/topic/13673/
        import random
            materials.
            # Bail when there is no object selected.
            if not isinstance(op, c4d.BaseObject):
                print ("Please select an object.")
            # Bail when the active object has no children.
            if len(op.GetChildren()) == 0:
                print ("Object has no children.")
            # Start an undo group.
            doc.StartUndo()
            # Iterate over all direct children of the selected object.
            for child in op.GetChildren():
                # Create a texture tag on the object and add an undo step for it.
                tag = child.MakeTag(c4d.Ttexture)
                doc.AddUndo(c4d.UNDOTYPE_NEWOBJ, tag)
                # Create a new material with a random color.
                color = c4d.Vector(random.uniform(0, 1),
                                   random.uniform(0, 1))
                material = c4d.BaseMaterial()
                material[c4d.MATERIAL_COLOR_COLOR] = color
                # Insert the material into the document, add an undo step and link the
                # material in the texture tag.
                doc.InsertMaterial(material)
                doc.AddUndo(c4d.UNDOTYPE_NEWOBJ, material)
                tag[c4d.TEXTURETAG_MATERIAL] = material
             # Close the undo group.
            doc.EndUndo()
        • W
          WDP
          yes I would like to change the view color for the wireframe model
          • ferdinandF
            ferdinand @WDP
            Hello WDP,
            you mean the display color of an object?
            It is just a parameter you can set as any other.
                """Sets the display color of the selected object to red.
                if op is None:
                # Set the "Display Color" parameter to "Custom"
                op[c4d.ID_BASEOBJECT_USECOLOR] = c4d.ID_BASEOBJECT_USECOLOR_ALWAYS
                # And set the "Color" parameter to red.
                op[c4d.ID_BASEOBJECT_COLOR] = c4d.Vector(1, 0, 0)
            if __name__=='__main__':
            • W
              WDP
              This post is deleted!
              • ferdinandF
                Hello @wdp,
                without any further questions we will consider this topic as solved by Friday, December the 17th.
