    How to find an object quickly?
    pythons22
    10 Posts 4 Posters 2.2k Views 2 Watching
    • chuanzhenC Offline
      chuanzhen
      If there are multiple objects with the same name and the same type in the object manager, what is the unique identification of each object.
      Thanks for any help!
      • CairynC Offline
        Cairyn
        Try BaseObject.GetGUID().
        chuanzhenC 1 Reply Last reply Reply Quote 0
          chuanzhen
          This post is deleted!
            chuanzhen @Cairyn
            @Cairyn
            Thanks,useful!
            Is there a way to directly obtain the object using this uniquely identified ID?
            CairynC 1 Reply Last reply Reply Quote 0
            • CairynC Offline
              Cairyn @chuanzhen
              @chuanzhen Not that I know of, since these are not links from some internal cache. You may need to write your own function to traverse the tree and compare manually.
              Unless some Maxon person knows a better way.
                chuanzhen @Cairyn
                @Cairyn
                It seems I should try some other solutions.Thanks for your help.
                • r_giganteR Offline
                  r_gigante
                  Hi @chuanzhen thanks for reaching out us.
                  With regard to your question, I warmly recommend also thinking of using FindUniqueID and looking at the section BaseList2D Manual::Unique ID or to make good use of BaseLink.
                  Finally with regard to get the object, either you traverse and compare again the unique ID or, by keeping your BaseLink list updated when add/deletion operations take place, you can look into the list and retrieve desired C4DAtom.
                  Cheers, R
                  • CairynC Offline
                    Cairyn
                    Considering that a UniqueID has to be registered with Maxon, this may not be the way to identify arbitrary objects within the object tree?
                    Seems to depend on the actual usecase. What is the final purpose here?
                      ferdinand @Cairyn
                      Hi @Cairyn,
                      @Cairyn said in How to find an object quickly?:
                      This only does apply to the case when one wants to add custom markers. Nodes are being automatically marked with MAXON_CREATOR_ID upon instantiation by Cinema 4D. The advantage of FindUniqueID is that it is a member of C4DAtom, i.e., far more versatile than BaseObject.GetGUID. I have used MAXON_CREATOR_ID in some of my posting here on Plugin Café and there were also a few threads covering it on the old forum; looking at these might clarify the usage.
                        chuanzhen @r_gigante
                        @r_gigante Thanks for your help!
