    MergeDocument() crash C4D
    python2026
    5 Posts 2 Posters 33 Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      c4d.documents.MergeDocument(doc, path_str,c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS,None)
      this code,c4d always crashed
      相信我,可以的!
      AnlvA 1 Reply Last reply Reply Quote 0
      • AnlvA Offline
        Anlv @chuanzhen
        Hi, @chuanzhen
        This code runs fine on my end (Cinema 4D 2026.3.4). Analyzing the cause of the failure may require more detailed information, such as the Cinema 4D version number and the real path (path resolution may occur), and corruption of the path_str file is also one possibility.
        Anlv
        chuanzhenC 1 Reply Last reply Reply Quote 0
          chuanzhen @Anlv
          @Anlv Hi
          Here is a video demonstrating how C4D crashes. For a saved document (or a loaded document), using MergeDocument() is fine, but for a new document that hasn't been saved, using MergeDocument() will definitely crash
          2026.3.3 win11
          相信我,可以的!
          • AnlvA Offline
            Anlv @chuanzhen
            Hi, @chuanzhen
            I tested the same code as you in both saved projects and unsaved new documents, but no crash occurred. This might be a bug, possibly related to the ObjectData plugin in your project. I can't be certain that's the cause. You could try ruling out the plugin's influence first. But this is beyond my capability, so let's wait for more professional personnel to help.
            Anlv
              chuanzhen @Anlv
              @Anlv Thanks for your reply.can't reproduce this issue on your side, it seems I need to test it on other computers. It's a puzzling problem
              相信我,可以的!
