    [Free Plugin]Plugin Debug Manager v1.3.0— Python Plugin Reloading for Cinema 4D
    plugin-informationdownloadprogramming
    3 Posts 2 Posters 355 Views 2 Watching
    • AnlvA Offline
      Anlv
      Hi everyone, I’m releasing Plugin Debug Manager, a debugging utility for Cinema 4D Python plugin development.
      When working on a .pyp plugin, changing a single entry file can otherwise require reloading every Python plugin—or restarting Cinema 4D. Plugin Debug Manager reads the currently registered Python plugins and lets developers reload only the entries they are testing.
      Main features:
      • Reads registered .pyp and .pypv plugins from Cinema 4D
      • Groups multiple registrations by their actual entry-file path
      • Displays plugin names, icons, decimal IDs, registration types, and full paths
      • Filters entries by filename or plugin ID
      • Reloads one plugin, selected plugins, or all reloadable plugins
      • Supports click-and-drag checkbox painting for batch selection
      • Persists checked entries and can move them to the top on demand
      • Provides Reload Plugin, Reload All, Fold All, and Unfold All context commands
      • Locates plugin files in Explorer or Finder through c4d.storage.ShowInFinder()
      • Continues processing when an individual plugin fails to reload
      Implementation details:
      • Registry entries are collected with c4d.plugins.FilterPluginList(c4d.PLUGINTYPE_ANY, True)
      • Entry files and registration metadata are obtained through BasePlugin.GetFilename(), GetID(), and GetType()
      • Selective reloads are performed with c4d.plugins.ReloadPythonPlugin()
      • ReloadDocumentAfterReload(True) is called only once after the reload batch
      Before reloading, the manager copies and normalizes the target file paths instead of retaining BasePlugin objects that may become invalid during the reload process. The manager itself remains visible in the list but cannot be selected or reloaded.
      Compatibility:
      • Current target: Cinema 4D 2026.3.3
      • Selective reloading depends on c4d.plugins.ReloadPythonPlugin, available in this version
      • Other Cinema 4D versions have not yet been verified
      Version: 1.3.0
      Plugin ID: 1069486
      Author: Anlv
      Download: Plugin Debug Manager v1.3.0.zip
      By the way, this is open source, and you can edit and modify it yourself to make it better suit your work habits.
      Best regards,
      Anlv
      • ferdinandF ferdinand pinned this topic on
        I have pinned this as extra tooling is always welcome 🙂 Thanks for sharing it !
        AnlvA 1 Reply Last reply Reply Quote 1
        • AnlvA Offline
          Anlv @ferdinand
          @ferdinand Thank you so much!
          I made some minor adjustments to the plugin, adding support for CTRL hotkey activation, which allows quick reloading of previously checked plugins that need to be reloaded without opening the window. As always, open source, and will continue to be open source.
          Download: Plugin Debug Manager v1.5.0.zip
          Anlv
