    TimeLine DopeSheet not update
    2026python
    5 Posts 2 Posters 952 Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      Hi
      in Dope Sheet -F-Curve mode,i change CTrack NBit(c4d.NBIT_TL1_SELECT2) ,(selection State),the window will not refresh immediately.
      After selection state change, how can I make the window refresh in real time
          for track in op.GetCTracks():
              track.ChangeNBit(c4d.NBIT_TL1_SELECT2,c4d.NBITCONTROL_SET)
      Thanks for any help!
      相信我,可以的!
        ferdinand @chuanzhen
        Hello @chuanzhen,
        Thank you for reporting this. At first glance this looks like a bug/regression in 2026.3.0. I'll have to check in more detail myself before I can say for sure. But your code is also incorrect, the NBIT_TLX_SELECT2 bits are internal and not for what you think they are. You must use NBIT_TLX_SELECT instead. But they are currently malfunctioning for me on Windows in 2026.3.
        Until I am sure, I will not yet classify this as a bug.
        In 2026.2.0, this code randomly selects and deselects tracks in an all timelines for the active object. I.e., you can spam-click the script and see the track selections 'jump around'. In 2026.3 it does exactly nothing (at least on my Windows machine).
        import random
                bit: int = random.choice([c4d.NBITCONTROL_SET, c4d.NBITCONTROL_CLEAR])
                for tl in (c4d.NBIT_TL1_SELECT, c4d.NBIT_TL2_SELECT, c4d.NBIT_TL3_SELECT, c4d.NBIT_TL4_SELECT):
                    track.ChangeNBit(tl, bit)
        ferdinandF 1 Reply Last reply Reply Quote 1
          ferdinand @ferdinand
          This is a bug. I have fieled it under 'ITEM#649699 Timeline does not react to NBIT selection changes on tracks anymore'. It is unfortunately not a bug in the Python or core C++ API which I could just fix myself, but either a bug in the scene evaluation or the timeline. So, we will have to wait until the owning team tackles it. I notified the owners that timeline automation is a popular scripting task and that they therefore should fix this.
          For now, the only thing I can recommend is to use 2026.2 when you want to carry out such tasks.
          chuanzhenC 1 Reply Last reply Reply Quote 0
          • ferdinandF ferdinand moved this topic from Cinema 4D SDK on
            chuanzhen @ferdinand
            @ferdinand Thanks for help
            相信我,可以的!
              Hey, good news, this is fixed in the upcoming hotfix (2026.3.2).
