    KeyFrame User Data from Xpresso driven User Data
    3 Posts 2 Posters 584 Views 1 Watching
    • J Offline
      JoelJohera
      To whom it may concern,
      I have an object that has two user data fields.
      I know that an Xpresso-driven user data field can not be animatable using keyframes, which is why I have the user data field keyframes. If I manually put the keyframes in the user data field keyframes with the same data as the Xpresso Driven user data field, everything works. However, I want it to make it work with a Python script, so I do not need to do the keyframes manually. I tried with this script:
      from c4d import gui
          obj = doc.SearchObject('Cube')
          desc_id_keyframes = None
          value = None
          user_data_container = obj.GetUserDataContainer()
          for desc_id, bc in user_data_container:
              if bc[c4d.DESC_NAME] == "Xpresso Driven":
                  value = obj[desc_id]
              elif bc[c4d.DESC_NAME] == "KeyFrames":
                  desc_id_keyframes = desc_id
          print(value)
          print(desc_id_keyframes)
          track = c4d.CTrack(obj, desc_id_keyframes)
          if not obj.FindCTrack(desc_id_keyframes):
              obj.InsertTrackSorted(track)
          curve = track.GetCurve()
          time = c4d.BaseTime(0, doc.GetFps())
          result = curve.AddKey(time)
          key = result["key"]
          key.SetValue(curve, value)
      However, the keyframe does not get inserted:
      What am I doing wrong?
      Thanks in advance for the help.
      Regards,
      Joel Johera
      • J Offline
        JoelJohera
        Solved.
        I need to change this part:
        track = obj.FindCTrack(desc_id_keyframes)
        if track is None:
          Hey @JoelJohera,
          it is kind of hard to follow your question and solution, as the former lacks a scene for context and for the latter I am not quite sure what you fixed. But when it works for you I am happy 😉
