    How do I return a list of names and ids for a drop down menu?
    windowspython2025
    3 Posts 2 Posters 395 Views 1 Watching
    • L Offline
      lionlion44
      I'm trying to automatically set a parameter on a shader. The parameter is a dropdown menu (combo box). The items in the drop down are dynamic so I can't just use a static number to set the parameter.
      I'm wondering if there's a way to read the names of the items and select the one I want based on the name?
      Something like:
      items = getComboBoxItems(c4d.SUBSTANCESHADER_CHANNEL)
      for item in items:
          if "roughness" in item.name:
              SubstanceShader[c4d.SUBSTANCESHADER_CHANNEL] = item.id
      • L Offline
        lionlion44
        found a solution:
        substance_shader = diffuse_shader.GetClone()
        mat.InsertShader(substance_shader)
        mat[c4d.OCT_MATERIAL_ROUGHNESS_LINK] = substance_shader
        desc = substance_shader.GetDescription(c4d.DESCFLAGS_DESC_NONE)
        parm_desc = desc.GetParameter(c4d.SUBSTANCESHADER_CHANNEL)
        cycle = parm_desc[c4d.DESC_CYCLE]
        for index, value  in cycle:
            if "roughness" in value.lower():
                substance_shader[c4d.SUBSTANCESHADER_CHANNEL] = index
                break
          ferdinand @lionlion44
          Hey @lionlion44,
          yes, that is the correct answer. The subject comes up from time to time, here is an answer of mine which is about the very case of yours - discovering substance channels.
