    Xpresso Object Index can not connect output ports with Python
    3 Posts 2 Posters 564 Views 1 Watching
    • J Offline
      JoelJohera
      To whom it may concern,
      I am trying to connect the outputs of an Object Index Node to other nodes. I know it can be done as via the GUI I can do it but I can not do it with Python.
      This is the code I have:
          null = doc.SearchObject("Null")
          sphere = null.GetDown()
          xtag = c4d.BaseTag(c4d.Texpresso)
          null.InsertTag(xtag)
          gv = xtag.GetNodeMaster()
          # Object Index Node
          object_index_node = gv.CreateNode(gv.GetRoot(), c4d.ID_OPERATOR_DETAILS)
          object_index_node_in_instance = object_index_node.GetInPorts()[0]
          object_index_node_out_index = object_index_node.GetOutPorts()[0]
          object_index_node_out_instance = object_index_node.GetOutPorts()[1]
          # Sphere Node
          sphere_node = gv.CreateNode(gv.GetRoot(), c4d.ID_OPERATOR_OBJECT)
          sphere_node[c4d.GV_OBJECT_OBJECT_ID] = sphere
          sphere_node_in_object = sphere_node.AddPort(c4d.GV_PORT_INPUT, c4d.GV_OBJECT_OPERATOR_OBJECT_IN)
          # Motion Data Node
          motion_data_node = gv.CreateNode(gv.GetRoot(), 1019010)
          motion_data_node_in_index = motion_data_node.GetInPorts()[0]
          motion_data_node_in_object = motion_data_node.GetInPorts()[1]
          # Connections
          object_index_node_out_instance.Connect(sphere_node_in_object)
          print(object_index_node_out_instance)
          object_index_node_out_index.Connect(motion_data_node_in_index)
          print(object_index_node_out_index)
      In the console, I get:
      False
      False
      I get this:
      And I am looking for this:
      Also I am using c4d.ID_OPERATOR_DETAILS to generate the node as in __init__.py matched the 400001152 number that the node has if it is created via the GUI.
      Thank you for your time.
      Joel Johera
        ferdinand @JoelJohera
        Hey @JoelJohera,
        your code simply contains a bug, you are using the wrong indices when you blindly index into the lists of ports.
            # Object Index Node
            object_index_node_out_index = object_index_node.GetOutPorts()[1] # You had the wrong indices here ...
            object_index_node_out_instance = object_index_node.GetOutPorts()[0] # ... and here.
            # Using indices the find ports is always a bit risky, because the user can reorder them.
            # Sphere Node
            # Motion Data Node
            # Connections
        • J Offline
          JoelJohera
          Thank you so much
