    Automatically solo objects by using the 'path' of the object manager?
    pythonr25
    4 Posts 2 Posters 1.7k Views 1 Watching
    • L Offline
      lionlion44
      Hey there,
      I'd love to be able to automatically solo the object that are inside the current 'path' parameter in the object manager. Is this possible using python or an easier method. This way the object manager and the viewport would have continuity with each other.
        ferdinand @lionlion44
        Hello @lionlion44,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: How to Ask Questions.
        About your First Question
        I do not really understand your question, specifically what you mean with 'current path of the object manager' and the Object Manager and viewport having 'continuity'. An Object Manager has no 'current path' and there is also more than one Object Manager (up to four). You can already link the active object state to the solo state of the scene graph, i.e., just select objects to solo them (see below). The only way to provide more 'continuity' would be to hide objects in the Object Managers which are not soloed. That would be technically possible, but not really a good idea, as you would then have no way to deselect these soloed objects as everything else would be hidden both in the viewport and Object Managers.
        • L Offline
          lionlion44
          Hey @ferdinand ,
          Thanks for the quick response. To describe my request more specifically, I was wondering if the path bar in an object manager could be used to solo objects. This way I could have multiple nulls containing different parts of the project, then by setting the root of the path bar to a null it would solo the things in that null. This would also mean I'm only seeing the soloed objects in the object manager. That's what I meant by continuity, the object manager and the viewport would have the same content.
          Ultimately, I'm trying to find a workflow that allows for isolating chunks of the project to be worked on one at a time but the basic solo feature is a bit. After doing a bit more research it looks like layers is the way to go. When using layers the solo feature hides the other layers in the viewport and the object manager. If the original idea is still possible I'd be interested, simply because I think it would be a bit more frictionless (no need to add object to layers, soloing tied to object hierarchy, workspaces inside of workspaces). But I understand it's a strange request. I'm comfortable using the standard layers and soloing features for now.
          Leo
            Hey @lionlion44,
            Well, doing what you want to do is only halfway possible. An object being soloed just means setting the flag EHIDE on all othe objects. And while there is OHIDE which can be used to hide scene elements in managers, e.g., an object in the Object Manager, it is not being used by the 'Set as Root/Path Bar'-function of the Object Manager. So, you cannot hook into that.
            What you can do is just write a simple script which operates both flags for you. But to make this air-tight, you will have to implement a plugin (to avoid accidentally saving a scene with hidden elements).
            Result
            Code
            """Demonstrates how to set the visibility of objects in the viewport and the managers.
            - When CTRL is not pressed while the script is invoked, the visibility state of the selected objects
              is set, i.e., everything that is not selected will be hidden.
            - When CTRL is pressed, the visibility state of the selected objects is cleared.
            - When HIDE_DESCENDANTS_OF_SELECTED_OBJECTS is set to True, the descendants of selected objects will
              be considered selected as well.
            WARNING: The visibility state is written PERMANENTLY into the scene graph, i.e., when one hides
            objects and saves the scene, the visibility state will be saved as well. One can of course just run
            the script while pressing CTRL to clear the visibility state of such saved and then loaded back
            scene, but this could possibly brick scenes for other users. To make this air-tight, one would have
            to implement a plugin which handles un-hiding objects before a scene is being saved (which is not
            super trivial in Python atm).
            Use this script at your own risk.
            __author__ = "Ferdinand Hoppe"
            __copyright__ = "Copyright 2025, Maxon Computer GmbH"
            import mxutils
            # Wether to hide objects that are descendants of selected objects. I.e., when you have A-> B -> C,
            # and A is selected, B and C will be considered selected as well.
            HIDE_DESCENDANTS_OF_SELECTED_OBJECTS: bool = True
            def IsSelected(node: c4d.BaseObject) -> bool:
                """Returns if #node is selected or if any of its predecessors are selected (when selecting
                descendants implicitly is enabled).
                while node:
                    if node.GetBit(c4d.BIT_ACTIVE):
                    if not HIDE_DESCENDANTS_OF_SELECTED_OBJECTS:
                        break
                    node = node.GetUp()
                return False
            def SetObjectVisibility(doc: c4d.documents.BaseDocument, clearSate: bool = False) -> None:
                """Sets the visibility of the object in the managers and the viewport.
                for node in mxutils.IterateTree(doc.GetFirstObject(), True, True, True):
                    isSelected: bool = clearSate or IsSelected(node)
                    node.ChangeNBit(c4d.NBIT_OHIDE, c4d.NBITCONTROL_CLEAR if isSelected else c4d.NBITCONTROL_SET)
                    node.ChangeNBit(c4d.NBIT_EHIDE, c4d.NBITCONTROL_CLEAR if isSelected else c4d.NBITCONTROL_SET)
                """Called by Cinema 4D whhen the
                if not op:
                    c4d.gui.MessageDialog("No object selected.")
                state: c4d.BaseContainer = c4d.BaseContainer()
                if not c4d.gui.GetInputState(c4d.BFM_INPUT_MOUSE, 0, state):
                    raise RuntimeError("Failed to get input state")
                ctrlIsPressed: bool = state[c4d.BFM_INPUT_QUALIFIER] & c4d.QUALIFIER_CTRL
                # If Ctrl is pressed, clear the visibility state, otherwise set it.
                SetObjectVisibility(doc, True if ctrlIsPressed else False)
