    Load presets args in python?
    windowspython2025
    7 Posts 2 Posters 3.3k Views 2 Watching
    • DunhouD Offline
      Dunhou
      Hey Community,
      I want to load some presets args for special objects, e.g, implement the function of selecting and loading preset buttons
      but I look the assets api handbook and the preset example, it need a PresetLoadArgs but it seems not valid in python.
      How can I achieve similar effects in existing versions?
      Cheers~
      DunHou
      https://boghma.com
      https://github.com/DunHouGo
        ferdinand @Dunhou
        Hey @Dunhou,
        Thank you for reaching out to us. No, you do not need PresetLoadArgs, these are only required when you want to handle preset asset drag events. To load a preset, you just need maxon.AssetCreationInterface, which has been wrapped for Python. The primary method to use for this would be GetDefaultSettings, which unfortunately is broken. I provide below a workaround with maxon.AssetCreationInterface.GetDefaultObject.
        Depending on what you want to do GetDefaultObject will work fine (when you just have to load a handful of predefined presets) or a bit clunky (when you have to discover all preset assets for a given scene element type).
        Because this concerns a bug, I have moved the topic.
        Result
        Code
        """Demonstrates how the find and apply preset assets.
        For this script to work sensibly, you should have a few preset assets for the Cube object, as
        accessible with the preset dropdown in the top right corner of the Attribute Manager.
        import maxon
            # Get the global asset repository and all preset assets in it.
            repo: maxon.AssetRepositoryRef = maxon.AssetInterface.GetUserPrefsRepository()
            presets: list[maxon.AssetDescription] = repo.FindAssets(
                maxon.AssetTypes.DefaultsPreset(), maxon.Id(), maxon.Id(), maxon.ASSET_FIND_MODE.LATEST)
            # Now iterate over all assets in it:
            for i, asset in enumerate(presets):
                c4d.gui.StatusSetBar(float(i) / float(len(presets)))
                c4d.gui.StatusSetText(f"Processing {i + 1} of {len(presets)} assets...")
                # Get the name of the asset.
                name: str = asset.GetMetaString(maxon.OBJECT.BASE.NAME, maxon.Resource.GetCurrentLanguage(), "")
                # This is how we would do this normally, but #GetDefaultSettings is brokeen. #types would
                # hold the BaseList2D types #asset is applicable to, and #settings would hold the data
                # container for the preset.
                # types: maxon.BaseArray[maxon.Int32] = maxon.BaseArray(maxon.Int32)
                # settings: c4d.BaseContainer = c4d.BaseContainer()
                # maxon.AssetCreationInterface.GetDefaultSettings(asset, types, settings)
                # As a workarround, we can do this, which even without inserting the nodes, is very much
                # not a cheap operation. Doing this for a handful of assets (e.g., a list of hard-coded
                # presets) is fine, but for all of them, it takes a while.
                op: c4d.BaseList2D = maxon.AssetCreationInterface.GetDefaultObject(asset)
                if not op:
                    continue
                # We found an Ocube asset.
                if op.CheckType(c4d.Ocube):
                    op.SetName(name)
                    doc.InsertObject(op)
            c4d.gui.StatusClear()
        DunhouD 1 Reply Last reply Reply Quote 0
        • ferdinandF ferdinand moved this topic from Cinema 4D SDK on
        • DunhouD Offline
          Dunhou @ferdinand
          Hey @ferdinand ,
          Thanks for the tips, sadly to see that GetDefaultSettings is broken, and I tried GetDefaultObject. It is way too slow, so I had to give up this until GetDefaultSettings fixed.
          Thanks for your time
          Cheess~
          DunHou
          https://boghma.com
            You could just do it in a thread in the background to cache the information.
            • DunhouD Offline
              Dunhou
              yes, but I want to use it in my own dialog, it needs to be as fast as normal drop down, but it is not a necessary function so I can wait for this.
              https://boghma.com
                well, that would not change anything about you being able to cache this. When your dialog is being opened, you start a thread which collects that information, and you then build your layout first without that information (i.e., empty combo boxes or wherever you want to put that information), when the thread is done, you invoke a layout rebuild which then uses that new information. You could of course also start the data collection earlier, e.g., when C4DPL_STARTACTIVITY is emitted. But make sure that you then call there WaitForDatabaseLoading.
                • DunhouD Offline
                  Dunhou
                  It sounds worth a try, but there may be latency issues when it comes to changes, or data changes can be manually processed during the changes
                  Perhaps for my needs, I can force the database to be use GetSceneRepository, anyway, it's worth a try. Thank you for your guidance 😊
                  https://boghma.com
