    Frozen Matrix different
    2025python
    4 Posts 3 Posters 1.8k Views
    • chuanzhenC Offline
      chuanzhen
      A parent object has 2 child objects whose global matrix are the same. They have the same frozen transform value, but the transform values are different. I used GetFrozenMln() to obtain the frozen matrix and found that the frozen matrix of the 2 child objects are *different.
      Why do 2 child objects have the same frozen transform value but different frozen matrix?
      相信我,可以的!
      chuanzhenC 1 Reply Last reply Reply Quote 0
        chuanzhen @chuanzhen
        When I restart C4D, I cannot reproduce this problem. It's really confusing, c4d 2025.2.1😵 (And I also forgot to save the file at that time, resulting in the loss of the file on site)
        相信我,可以的!
        • i_mazlovI Offline
          i_mazlov @chuanzhen
          Hi @chuanzhen,
          Glad to hear the issue went away.
          Just to note, the frozen matrices are designed in a way that simulate behavior of an intermediate parent null object, i.e. just as if you had an invisible parent null object with matrix being equal to the frozen one. Sometimes it can get confusing, because the way the global matrix of the object is calculated is effectively:
          [Local Matrix] = [Frozen Translation] * [Frozen Rotation] * [Relative Translation] * [Relative Rotation] * [Frozen Scale] * [Relative Scale]
          If the relative transform (the main one) and the frozen transform are the same for two objects, given they are children of the same parent and there're no other 3rd parties involved (e.g. plugins, python tags etc), the global transform matrices of these two objects are the same.
          Please find more useful insights in our great Matrix Manual.
          Ilia
          kangddanK 1 Reply Last reply Reply Quote 0
          • kangddanK Offline
            kangddan @i_mazlov
            @i_mazlov said in Frozen Matrix different:
            象,并且没有其
            I found that it's very similar to the offsetParentMatrix attribute introduced in Maya 2020.:)
            https://github.com/kangddan
