    Xpresso python tag issue
    2025python
    5 Posts 2 Posters 1.0k Views 1 Watching
    • A Offline
      arjo
      This script in the xpresso python tag works fine in Cinema 4D R19 but it doesn't work in higher versions. When I click on compile it says "no errors". The script should write spline data that I use in a range mapper node. But when I connect the output ports to the range mapper spline input port both the python and the range mapper turn yellow. Does anybody have an idea why this works in older versions of Cinema 4D but not in 2025?
      import math
          global steps #number of steps
          global stepsize #size of each step
          global skidstep #spline data for range mapper
          global returnstep #spline data for range mapper
          points = steps * 2
          Xstep = 1 / points
          Ystep = 1 / steps
          points = points + 1
          skidstep = c4d.SplineData()
          skidstep.MakePointBuffer(points)
          returnstep = c4d.SplineData()
          returnstep.MakePointBuffer(points)
          X = 0
          Ya = 0
          Yb = 1
          step = 0
          while step < points:
              vec_A = c4d.Vector(X, Ya, 0)
              vec_B = c4d.Vector(X, Yb, 0)
              skidstep.SetKnot(step, vec_A)
              returnstep.SetKnot(step, vec_B)
              X = X + Xstep
              step = step + 1
              if step % 2 != 0:
                  Ya = Ya + Ystep
                  Yb = 0
                  Yb = 1
        ferdinand @arjo
        Hello @arjo,
        Thank you for reaching out to us. Without your scene file there is not much what we can do for you. That code, at a glance, is correct.
        • A Offline
          arjo @ferdinand
          @ferdinand skidding.c4d
            ferdinand @arjo
            Hey @arjo,
            There are errors in your console, and they tell you exactly what the issue is. Your steps variable is not an integer and MakePointBuffer expects an integer for its number of points.
            Before
            and after, I just cast points to int:
            • A Offline
              arjo
              Ah, super! thank you.
