    How to Activate Polygon Selection in the Selection Filter
    2024python
    3 Posts 2 Posters 1.2k Views 1 Watching
    • S Offline
      seora
      Hi, I was wondering if there is any code related to the selection filter in the c4d python SDK. Specifically, I would like to create a script that ensures only polygons are active in the selection filter.
      Could you provide any relevant information or examples that could help with this?
        ferdinand @seora
        Hey @seora,
        Thank you for reaching out to us. Selection filter modes are just commands. Since there is no GUI involved with most of them, you can just 'record' your actions with the script log and then 'play' that back. Just to be clear, you can also invoke commands that entail GUI, e.g., the "Selector .." command, but you cannot automate that GUI (as GUIs are generally not exposed in the API).
        """A simple script that disables all selection filters, and then just enables the polygons filter.
        from typing import Optional
        doc: c4d.documents.BaseDocument # The active document
        op: Optional[c4d.BaseObject] # The active object, None if unselected
            """Called by Cinema 4D when the script is executed.
            c4d.CallCommand(69000, 902) # Set selection filter to None.
            c4d.CallCommand(69000, 904) # Enable Polygon filter.
        • S Offline
          seora
          @ferdinand Your response was helpful. Thank you:)
