    Creating a Playblast script falling at the hurdle.
    windowspython2024
    3 Posts 2 Posters 679 Views 1 Watching
    • A Offline
      AG_Vivimagic
      I am creating a playblast script where it will automate the render settings for the project file and playblast render settings. Code below.
      from c4d import documents, plugins, storage, utils
      doc[c4d.DOCUMENT_FPS] = 25 #set file fps
      newRenderData = c4d.documents.RenderData()
      newRenderData.SetName('Playblast')
      doc.InsertRenderDataLast(newRenderData)
      doc.SetActiveRenderData(newRenderData) #make it active
      newRenderData.SetBit(8) #make it selected
      render_data = documents.GetActiveDocument().GetActiveRenderData()
      c4d.CallCommand(12161) # Render Settings
      newRenderData[c4d.RDATA_RENDERENGINE] = 300001061 #create Viewport Renderer
      newRenderData[c4d.RDATA_XRES] = 1920 #width
      newRenderData[c4d.RDATA_YRES] = 1080 #height
      newRenderData[c4d.RDATA_FRAMERATE] = 25 #set render fps to 25
      newRenderData[c4d.RDATA_FRAMESEQUENCE] = 2 #Frame range to "All Frames"
      newRenderData[c4d.RDATA_FORMAT] = 1125 #MP4 format
      newRenderData[c4d.RDATA_XRES_VIRTUAL] = 1920 #width
      newRenderData[c4d.RDATA_YRES_VIRTUAL] = 1080 #height
      c4d.EventAdd(c4d.EVENT_FORCEREDRAW)
      I am getting the render settings to align and execute however it is not updating the UI. It need to look like this !Untitled-1.png image url) Not this Annotation 2025-01-22 094235.jpg
        ferdinand @AG_Vivimagic
        Hello @AG_Vivimagic,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        First of all, your script strikes me as sourced from or at least written with the help of a chat bot. Please disclose when you use AI, otherwise we might refuse to help you. Please also have a look at Support Procedures: Asking Questions, 'I am getting the render settings to align and execute however it is not updating the UI. It need to look like this !' is not a proper question.
        I am assuming that you want to have similar setup of video post effects in your render data, as if when you choose the Preview Hardware Renderer manually. To achieve that, you must manually curate the effects. You should also avoid using raw integer values when setting parameters, as this leads to confusing code and easily to errors. newRenderData.SetBit(8) #make it selected does for example not do what you think it does. The value 8 is BIT_ENABLEPAINT, but you probably mean here BIT_ACTIVE (2).
        Result
        Code
            # Set the document FPS.
            # Create a new render data instance with the values you wanted.
            rdata: c4d.documents.RenderData = c4d.documents.RenderData()
            rdata.SetName("Playblast")
            rdata[c4d.RDATA_RENDERENGINE] = c4d.RDATA_RENDERENGINE_PREVIEWHARDWARE
            rdata[c4d.RDATA_XRES_VIRTUAL] = 1920
            rdata[c4d.RDATA_YRES_VIRTUAL] = 1080
            rdata[c4d.RDATA_FRAMERATE] = 25
            rdata[c4d.RDATA_FRAMESEQUENCE] = c4d.RDATA_FRAMESEQUENCE_ALLFRAMES
            rdata[c4d.RDATA_FORMAT] = c4d.FILTER_MOVIE
            # We must now curate the video post effects for this render data. This is probably a bit overkill,
            # we could also just delete all of them, since we know that the Preview Renderer only uses MBL which
            # cannot be removed. But there could be a third party effect which supports the preview renderer
            # and which is present by default, so we do it the proper way by checking each effect for being
            # compatible with the selected render engine.
            effect: c4d.documents.BaseVideoPost = rdata.GetFirstVideoPost()
            while effect:
                nxt: c4d.documents.BaseVideoPost = effect.GetNext()
                if not effect.RenderEngineCheck(c4d.RDATA_RENDERENGINE_PREVIEWHARDWARE):
                    effect.Remove()
                effect = nxt
            # Add the native RDATA_RENDERENGINE_PREVIEWHARDWARE effect.
            previewEffect: c4d.documents.BaseVideoPost = c4d.documents.BaseVideoPost(
            rdata.InsertVideoPostLast(previewEffect)
            # Insert the render data and do the other things you wanted to do.
            doc.InsertRenderDataLast(rdata)
            doc.SetActiveRenderData(rdata)
            rdata.SetBit(c4d.BIT_ACTIVE)
        • A Offline
          AG_Vivimagic
          That is perfect, thank you for being through and concise, lifesaver.
