    python script change Redshift setting
    pythonwindows2024
    6 Posts 3 Posters 2.1k Views 1 Watching
    • R Offline
      RTF
      I want to write a script to set the Settings of Redshift Matpreview
      But
      import c4d.documents
      import redshift
      import os
      def FindVideoPost(renderData, pluginId):
          vp = renderData.GetFirstVideoPost()
          while vp is not None:
              if vp.IsInstanceOf(pluginId):
                  return vp
              vp = vp.GetNext()
          return None
      def FindAddVideoPost(renderData, vpPluginID):
          vp = FindVideoPost(renderData, vpPluginID)
          if vp is None:
              vp = c4d.documents.BaseVideoPost(vpPluginID)
              if vp is not None:
                  renderData.InsertVideoPost(vp)
          return vp
          renderdata = doc.GetActiveRenderData()
          vprs = FindAddVideoPost(renderdata, redshift.VPrsrenderer)
          if vprs is None:
          # Switch renderer
          renderdata[c4d.RDATA_RENDERENGINE] = redshift.VPrsrenderer
          # Set Redshift render parameters
          vprs[c4d.PREFS_REDSHIFT_MATPREVIEW_MODE] = 1
          # Refresh UI
          # print("Render settings updated to 4K and frame range set to All Frames.")
      # Execute the main function
      This code doesn't seem to have any effect
      Then I changed the method and set the code in C4D
      from c4d import gui
      def set_amlimit_preference():
          # 获取全局设置容器
          bc = c4d.GetWorldContainerInstance()
          # 设置新的值为 666
          bc[c4d.PREFS_REDSHIFT_MATPREVIEW_MODE] = 1
          # 应用修改后的设置
          c4d.SetWorldContainer(bc)
          # 保存设置到磁盘
          c4d.SaveWorldPreferences()
          # 尝试刷新界面
      # 运行函数
      Can not be modified successfully
      Can someone help me
      DunhouD 1 Reply Last reply Reply Quote 0
      • DunhouD Offline
        Dunhou @RTF
        Hi @RTF , the c4d.PREFS_REDSHIFT_MATPREVIEW_MODE doesn't seem stored in Redshift VideoPost, is this code generated by GPT or something similar?
        Back to the topic, this parameter is stored in the Redshift tab of the preferences node. You should get the redshift preference node and then set the parameter.
        If you installed Renderer lib or boghma hub, you can use this:
        from Renderer import Redshift
            Redshift.SetMaterialPreview(preview_mode = 1)
        or just few codes:
        ID_PREFERENCES_NODE = 465001632 # Prefs ID
        def GetPreference() -> c4d.BaseList2D:
            Get the Redshift preferenc.
            prefs: c4d.plugins.BasePlugin = c4d.plugins.FindPlugin(ID_PREFERENCES_NODE)
            if not isinstance(prefs, c4d.BaseList2D):
                raise RuntimeError("Could not access preferences node.")
            descIdSettings = c4d.DescID(
            c4d.DescLevel(1036220, 1, 465001632), # pref ID Redshift
            c4d.DescLevel(888, 133, 465001632)
            return prefs[descIdSettings]
            redshift_pref: c4d.BaseList2D = GetPreference()
            redshift_pref[c4d.PREFS_REDSHIFT_MATPREVIEW_MODE] = 1
        Cheers~
        DunHou
        https://boghma.com
        https://github.com/DunHouGo
        R 1 Reply Last reply Reply Quote 2
        • R Offline
          RTF @Dunhou
          @Dunhou
          Thank you for your help, but after I run the following code, the Redshift Settings have not changed
          By the way I am a python novice and the above code is written by GPT
          I just want to use the script to change the Settings of the image below
          • DunhouD Offline
            Dunhou
            you need to change the id of you want
            PREFS_REDSHIFT_MATPREVIEW_MODE_BACKGROUND: int = 3
            PREFS_REDSHIFT_MATPREVIEW_MODE_IDLE: int = 1
            PREFS_REDSHIFT_MATPREVIEW_MODE_OFF: int = 0
            PREFS_REDSHIFT_MATPREVIEW_MODE_SUSPEND: int = 2
            https://boghma.com
            R 1 Reply Last reply Reply Quote 0
            • i_mazlovI Offline
              i_mazlov @RTF
              Hello @RTF,
              Getting Started
              It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
              About your First Question
              The second way that @Dunhou (thank you for being an active part of our community!) has suggested for you is actually the recommended one. The only missing part is executing c4d.EventAdd() in the end, which is likely the reason why you don't see any changes after running the script.
              If you'd like to get more explanation on this code, please check this great example code posted by Ferdinand: Python: How to get axis scale from the preference settings?
              Ilia
              • R Offline
                RTF @Dunhou
                @Dunhou @i_mazlov
                Thanks a lot.😊 😊 😊
