    Plugin Which Creates MenuItems with Scripts ( not from user folder )
    programmingchit-chat
    4 Posts 2 Posters 2.1k Views
    • G Offline
      Gemini
      Hey,
      Can it be possible to create a user menu from a plugin with scripts ( lines ) which are not registered in the c4D user preference folder ? ( "c:\Users\xxx\AppData\Roaming\Maxon\Maxon Cinema 4D YY" )
      Thanks in advance,
      G
      • G Offline
        Gemini
        Anyone here ? Any practice like this ?
        • i_mazlovI Offline
          i_mazlov @Gemini
          Hi @Gemini,
          please excuse the delayed answer.
          It's hard to understand what exactly you're asking about.
          If you want to create custom menu, please check the following threads:
          Building menus with C4DPL_BUILDMENU in S26+
          How to add "scripts" to a menu?
          If your question is anyhow related to loading plugins from custom location, please check the g_additionalModulePath argument. Related discussion was in the following thread:
          how to program plugins with python?
          Otherwise, please give a more detailed description of what specifically you're trying to achieve.
          Ilia
          • G Offline
            Gemini
            I just simply add a plugin to C4D which creates a user menu into C4D all in one pack without adding any script into the user C4D preferences folder ( library / scripts ) . Menu and script embedded solution all in one plugin inside.
