    Add Expression Value in Render Settings Save Path
    chit-chatprogramminglearning-resource
    8 Posts 4 Posters 3.9k Views 1 Watching
    • G Offline
      Gemini
      Is there a chance to add an expression result of python ( for me the mayor version from the C4D file name ) to the Render Settings Path string ? I would not use c++ custom token, because I'm not familiar in C++. šŸ˜‰
      Thanks ! šŸ™‚
      G
      DunhouD i_mazlovI 2 Replies Last reply Reply Quote 0
      • DunhouD Offline
        Dunhou @Gemini
        Hey @Gemini ,
        You should take a look at py-render-token example, and filter the version number of your project like re.findall("v"+"\d+",filePath) if I understand not wrong.
        Cheers~
        DunHou
        https://boghma.com
        https://github.com/DunHouGo
        • i_mazlovI Offline
          i_mazlov @Gemini
          Hi @Gemini,
          Getting Started
          It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
          About your First Question
          There's no built-in token for this, so you would need to manually parse the document file path for the necessary information (e.g. using regular expressions) and adjust the render settings correspondingly.
          Depending on the desired behavior you'd like to achieve, the implementation can be slightly different.
          If you'd like to create custom token, which contains your extracted information, please check the posting from Dunhou (thanks for taking an active role in the community!).
          In case you'd like to have a script that asjusts the filepath, please have a look at the render settings example. For the "File" field you'd need to use c4d.RDATA_PATH token.
          Ilia
          • G Offline
            Gemini
            Thanks for your answer.
            Tokens are working well but I have a strange issue with them at the multi pass files, if I end the file with a string ( here 'XXX') the file works well but If not it adds '1' to it. Do I miss something in the process ? I think my python token string could not generate that end string there.
            • G Offline
              Gemini
              Copyright: MAXON Computer GmbH
              Author: Maxime Adam
              Description:
                  - Registers two Tokens plugin. One visible in the render setting the other one not.
                  - A token is a string that will be replaced during the token evaluation time by a string representation.
              Class/method highlighted:
                  - c4d.plugins.RegisterToken
                  - c4d.plugins.RegisterHiddenToken
              import re
              from c4d import documents
              def majorVersionToken(data):
                  """The function that will be called to return the string representation of a token.
                  Args:
                  Returns:
                      str: The string that will replace the token
                  # Get the file path of the current document
                  file_name = doc.GetDocumentName()
                  match = re.search(r'v\d{0,10}', file_name)
                  version = 'v001'
                  if match:
                      version = 'v' + match.group().replace('v','').zfill(3)
                      # print("No match found")
                      pass
                  return str(version)
              def minorVersionToken(data):
                  Args:
                  Returns:
                  # file_path = doc.GetDocumentPath()
                  match = re.search(r'_\d{0,10}', file_name)
                  version = '001'
                  if match:
                      version = match.group().replace('_','')
                      if len( version) <= 3:
                          version = version.zfill(3)
                      pass
                  return str(version)
              def shortProjectNameToken(data):
                  Args:
                  Returns:
                  file_name = documents.GetActiveDocument().GetDocumentName()
                  match = re.search(r'v\d{0,3}', file_name)
                  token = file_name.split( match.group())[0].rstrip('_')
                  return str(token)
              def PythonHiddenToken(data):
                  Args:
                  Returns:
                  # Returns the frame number as a string. So this will replace the token by the frame number.
                  return str(data[4])
                  # First it's important to check if the token is not already registered
                  for registeredToken in c4d.modules.tokensystem.GetAllTokenEntries():
                      # Checks if the token name is already used, if it's the case exit.
                      if registeredToken.get("_token") in ["majorVersionToken", "PythonHiddenToken"]:
                          exit()
                  # Registers the token "PythonToken" that will be visible in te render setting.
                  c4d.plugins.RegisterToken("mver", "_Project Mayor Version", "v002", majorVersionToken)
                  c4d.plugins.RegisterToken("nver", "_Project Minor Version", "002", minorVersionToken)
                  c4d.plugins.RegisterToken("shortproject", "_Project Short Name", "scene", shortProjectNameToken)
                  # Registers the token "PythonHiddenToken" it will not be visible in te render setting.
                  c4d.plugins.RegisterHiddenToken("PythonHiddenToken", "This is a Hidden Python Token", "001", PythonHiddenToken)
              • S Offline
                shivamist
                If i'm not mistaken, "_1" is generated by Redshift if the "Regular Image" filename and the "Multi-Pass Image" filename are the same
                Same filename :
                Changing "-" to "_" at the end of the file :
                • G Offline
                  Gemini
                  Ups. Maybe. I'm checking..
                  • G Offline
                    Gemini
                    The extension is different. So the file name too.
