    Vertex Map Tag not in sync error
    python2024windows
    3 Posts 2 Posters 998 Views
    • D Offline
      danniccs
      I am running the following code to create a vertex map tag on an object (targetObject is a sphere BaseObject every time I call the function):
      # Make object editable
      res = c4d.utils.SendModelingCommand(
      		command = c4d.MCOMMAND_MAKEEDITABLE,
      		list = [targetObject],
      		mode = c4d.MODELINGCOMMANDMODE_ALL,
      		doc = doc )
      if res is False or res is True:
      	raise TypeError()
      elif isinstance( res, list ):
      	doc.InsertObject( res[0] )
      vertexMapTag = res[0].GetTag( c4d.Tvertexmap )
      if vertexMapTag is None:
      	vertexMapTag = c4d.BaseTag( c4d.Tvertexmap )
      	vertexMapTag[c4d.ID_TAGFIELD_ENABLE] = True
      	vertexMapTag[c4d.ID_TAGFIELD_INVERT] = False
      	vertexMapTag[c4d.ID_TAGFIELD_DEFORMED] = False
      	res[0].InsertTag( vertexMapTag )
      After running this I get a sphere with a UVW tag and a vertex map tag, as intended. However, when I select the sphere and select the paint tool, I get the following error:
      What is causing the tag to not be in sync?
      Thank you for your help,
      Daniel
      • i_mazlovI Offline
        i_mazlov @danniccs
        Hi Daniel,
        Please excuse the delayed answer.
        You're not supposed to create tags via constructor. It's expected to be created using MakeVariableTag() function instead. Please have a look at Ferdinand's example here: Negative Vertex Map values
        Ilia
        • D Offline
          danniccs
          Hi Ilia,
          Thank you very much, I was not aware of that!
          Cheers!
