    Compilation of Extended SDK C++ SDK will halt on macOS for SDKs older than 2024.4.0
    c++macos
    8 Posts 2 Posters 2.5k Views 2 Watching
    • K Offline
      kitbash_ave
      Hello!
      I'm running into the following build error when building my plugin using the 2024.0.2 sdk. When I build with the 2024.5 sdk my plugin builds fine, but I'd like to support as many versions of C4D as possibe.
      error: can't exec '../../../frameworks/settings/ccache-clang.sh' (No such file or directory)
      Command ../../../frameworks/settings/ccache-clang.sh failed with exit code 71
      I've confirmed the file is at the location being searched for.
      Configuration:
      Error occurred while building core.framework.
      Building on macOS Monterey 12.7.6 with Xcode 13.4.1 utilizing legacy build system.
      Additionally I attempted to build with the 2023.0 SDK and had the same error.
      Avery Stauber
      3D Graphics Pipeline Engineer - Kitbash3D
        ferdinand @kitbash_ave
        Hey @kitbash_ave,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        You are likely ignoring this warning from out Getting Started: First Steps manual:
        Once you have unpacked an SDK on Windows you cannot use it on macOS without resetting its file permissions. An SDK unpacked under macOS can always be migrated to Windows. Such 'tainted Windows SDK' might fail to compile on macOS.
        What the warning does not mention, is that unpacking the SDK on Windows will also often screw up your line endings. In our SDK package generator we have therefore a section where we reset the line endings to Linux style inside the zip package for exactly these two shell scripts (as the generators usually run on Windows machines). Once you unpack the SDK, Windows/the zip tool will usually enforce Windows style line endings. The easiest way for you to fix this, is to download a matching extended SDK, then unpack it on macOS, and replace the frameworks from that SDK with your tainted frameworks. Technically you could also just update the two shell scripts used by XCode's Clang but I would advise against piecing together an SDK from multiple sources, as this can easily lead to problems.
        • K Offline
          kitbash_ave
          Hey Ferdinand! Great to be here, and thanks for the super fast response. πŸš€
          Currently I was testing only on a macOS machine. Just to double check I didn't bork anything I just did the following steps to try again all on macOS:
          1. Download SDK 2024.0.2 C++ sdk from the sdk downloads page.
          2. Extracted it to my downloads folder.
          3. Ran ./generate_solution_osx.command
          4. Opened ./solution_osx.command
          5. Changed build system to legacy, schema to AllTargets, and tried to build
            Ran into the same issue here:
          Avery Stauber
            Hey @kitbash_ave,
            I will give it a spin tomorrow, to see what is what. Your steps are correct, and you are using the correct OS and XCoode.
            • K Offline
              kitbash_ave
              Thanks for looking into this Ferdinand and have a great evening!
              Avery Stauber
              • ferdinandF ferdinand moved this topic from Cinema 4D SDK on
                Hello @kitbash_ave,
                so, I had a look, and we ship extended legacy SDKs with incorrect line endings for the files ccache-clang.sh and ccache-clang++.sh. This is a bug and I therefore moved this topic to the bug forum and also slightly modified the title.
                Legacy SDKs means all SDKs to which we applied the extended SDK retroactively, i.e., everything before 2024.4.0. The 2024.4.0, 2024.5.0, and most importantly 2025.0.0 extended SDK are not affected by this. The sdk.zip shipped with a Cinema 4D installation was never affected by this.
                We will fix this in a timely manner, as this is a critical bug, but I have to fix the package generation for the legacy SDKs for that (I probably forgot there the step to sanitize line endings) and doing that will probably take me at least a few days. So, for now we must ask you to fix this yourself.
                ⚠ Do not overwrite these files with files you have sourced from another SDK. Doing this within a perfect version match, e.g., sdk.zip for 2023.0.1 and Extended SDK 2023.0.1 is fine but these files do change over time and you will break things if you mismatch them.
                Option 1
                Simply navigate towards {EXTENDED_SDK}/frameworks/settings/ccache-clang.sh and ccache-clang++.sh and set the line endings to LF. I also show in the video how to do this with VS Code as an example editor.
                Option 2
                Alternatively you could also write a little shell script which does this for you. This can be useful if you want to automate this for multiple SDKs. I also showcase how to do this in the video, my script I provided below expects to be placed in a subdirectory of the SDK, e.g. {EXTENDED_SDK}/tools/fix_line_endings.sh.
                #!/bin/bash
                # Enforces LF line endings for the two clang cache scripts in the Cinema 4D SDK.
                # Expects to be placed in the tools directory of the Extended Cinema 4D SDK.
                TARGET_DIR="../frameworks/settings"
                FILES=("ccache-clang.sh" "ccache-clang++.sh")
                if [ ! -d "$TARGET_DIR" ]; then
                  echo "Target directory $TARGET_DIR does not exist."
                  exit 1
                fi
                for filename in "${FILES[@]}"; do
                  file="$TARGET_DIR/$filename"
                  path=$(realpath "$file")
                  if [ -f "$file" ]; then
                    sed -i '' 's/\r$//' "$file" # Convert CRLF to LF
                    sed -i '' 's/\r//' "$file" # Convert CR to LF
                    echo "Enforced LF line endings for $path."
                  else
                    echo "The file $path does not exist, you are running this script on an irregular C++ SDK."
                  fi
                done
                I hope this help and cheers,
                Video
                Here I explain this a bit try subject in a more tangible way:
                • K Offline
                  kitbash_ave
                  Exactly the problem Ferdinand, thanks for the speedy fixes! Successfully building on 2024.0.2 and 2023.0.1 sdks.
                  -Avery
                  Avery Stauber
                    Hey everyone,
                    I fixed the issue, the legacy SDKs now have again the correct line endings, the downloads have been updated.
