    How to hide an object's native attributes
    windows2024python
    3 Posts 2 Posters 1.3k Views
    • O Offline
      Oliver
      Hello all, I would like to know if C4D can hide an object's native attributes (e.g., hiding the Object tab of a spline object). This would help avoid unnecessary attributes when selecting the corresponding controllers while animating, thus improving efficiency. In the following code, I found that SetParameter doesn't work. I can only hide custom user data attributes šŸ˜ž
         obj = op
         description = obj.GetDescription(c4d.DESCFLAGS_DESC_NONE)
         doc.StartUndo()
         for bc, paramId, groupId in description:
             if bc[c4d.DESC_NAME] == 'Object Properties':
                 doc.AddUndo(c4d.UNDOTYPE_CHANGE, obj)
                 print(bc[c4d.DESC_HIDE])                    #  return None
                 bc[c4d.DESC_HIDE] = False
                 obj.SetParameter(groupId, bc, c4d.DESCFLAGS_SET_NONE)
               # obj.SetUserDataContainer(groupId, bc)      # hide userData attr
                 obj.Message(c4d.MSG_CHANGE)
         doc.EndUndo()
      • i_mazlovI Offline
        i_mazlov @Oliver
        Hi @Oliver,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        The GetDescription() function returns a copy of the object's description, which means that any modifications will be on the local description instance and will not be reflected on the object itself:
        This effectively means that you don't have any control to hide existing attributes in the description your plugin doesn't own.
        Ilia
        O 1 Reply Last reply Reply Quote 1
        • O Offline
          Oliver @i_mazlov
          @i_mazlov Thank you
