    Export RSproxy with Python
    4 Posts 3 Posters 1.4k Views 1 Watching
    • R Offline
      Richard-Prism
      is there any documentation or examples about how to export selected objects as rsproxies?
      Specifically I'm looking for the format, which need to be used in the c4d.documents.SaveDocument function.
      DunhouD i_mazlovI 2 Replies Last reply Reply Quote 0
      • DunhouD Offline
        Dunhou @Richard-Prism
        Hey @Richard-Prism ,
        You can check the my custom library Renderer.Redshift.Scene on Github here , witch also can visit from General Talk, and modify the codes, or just use this if match what you need.
        Nothing special here.
        Cheers~
        DunHou
        from Renderer import Redshift
            scene_helper = Redshift.Scene(doc)
            scene_helper.auto_proxy(node=op, remove_objects=False)
        https://boghma.com
        https://github.com/DunHouGo
        • i_mazlovI Offline
          i_mazlov @Richard-Prism
          Hi @Richard-Prism,
          Getting Started
          It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
          About your First Question
          For the example usage of the SaveDocument function you can check one of our examples in the github repo, e.g. Export Alembic example.
          Regarding the RS Proxy exporter, it is available only if you have redshift enabled in you cinema 4d. Hence, you won't be able to find its ID in the C4D documentation. However, you can always use Script Log (Extensions -> Script Log) to track down the ID of the RS Proxy exporter.
          Then just make an ordinary RS Proxy export and you'll see the ID in the script log:
          99a32704-8a66-4592-a420-7b6220d2d248-image.png.
          @Dunhou, thank you for actively participating in our discussions and offering and alternative solution!
          Ilia
          • R Offline
            Richard-Prism
            Great, thank you both very much. That helped a lot and I got the export working!
