    wrong results when rendering using fields within a python effector
    python2024windows
    3 Posts 2 Posters 1.4k Views 1 Watching
    • T Offline
      TSD
      Hello, I've got a problem using the Clone object with a Python Effector that uses a field. I hope this is the right subforum for this kind of problem.
      The Python-Code:
      md = mo.GeGetMoData(op)
      fall = md.GetFalloffs()
      print("fall "+str(fall))
      In the Editor it returns a number like it should, but when I render it always returns 0.0. I've attached the C4D File including a screenshot. I'm using the latest C4D Version 2024.3.2
        Hi thanks for reporting it, this will be fixed in an upcoming release (not necessary the next one).
        As a workaround you can sample the field yourself like so:
        from c4d.modules import mograph as mo
        #import redshift
        def CustomGetFalloffsForFields():
            mdcount = md.GetCount()
            # Prepare FieldOutput
            flags = c4d.FIELDSAMPLE_FLAG_VALUE
            outputs = c4d.modules.mograph.FieldOutput()
            outputs.Resize(mdcount, flags)
            # Prepare FieldInputs values
            mdmat = md.GetArray(c4d.MODATA_MATRIX)
            positions = [matrix.off for matrix in mdmat]
            normals = [matrix.v3 for matrix in mdmat]
            uvws = md.GetArray(c4d.MODATA_UVW)
            callerMG = gen.GetMg() if gen and gen.IsInstanceOf(c4d.Obase) else Matrix()
            inputs = c4d.modules.mograph.FieldInput(positions, len(positions), callerMG)
            # Prepare FieldInfo values
            callerStack = c4d.modules.mograph.FieldCallerStack()
            callerStack.Add(gen)
            infos = c4d.modules.mograph.FieldInfo()
            infos._flags = flags
            infos._callerThread = c4d.threading.GeGetCurrentThread()
            infos._doc = gen.GetDocument()
            infos._callerStack = callerStack
            infos._inputData = inputs
            # Sample the field
            op[c4d.FIELDS].SampleList(infos, inputs, outputs)
            return outputs._value
            if md is None: return False
            cnt = md.GetCount()
            fall = CustomGetFalloffsForFields()
            for i in range(0, cnt):
                if fall[i] > 0:
                    print("################## YES!!! IVE FOUND A PRODUCT!!!")
        • M m_adam moved this topic from Cinema 4D SDK on
        • T Offline
          TSD
          Hi Adam, thanks for the update and the workaround! 👍
