    get the names of redshift multi passes AOV names from the render settings
    Cinema 4D SDK
    python 2023
    1.4k
    • T
      thomas
      I am looking for a way to read out the multipass names of my redshift rendersettings, such as 'Z' or 'depth'
      in the code below the script successfully gives me the path at the very last print statement. I am looking for the other MP filenames
      filepath 2: C:\Users\thoma\Dropbox\trauminc\projects\832-control_net\work\CG\c4d\balls\render\balls-v010\balls-v010.png, 1023671 defined in the render settings. such as balls-v010_depth0034
          def render(self, url):
                  print(f"are we rendering? {self.rendering}")
                  if self.rendering:
                  self.rendering = True
                  docClone = doc.GetClone()
                  rd = doc.GetActiveRenderData()
                  print(f"render data: {rd}")
                  print(f"multipass {rd.GetFirstMultipass()}")
                  bmPreview = c4d.bitmaps.BaseBitmap()
                  bmPreview.Init(int(rd[c4d.RDATA_XRES]), int(rd[c4d.RDATA_YRES]))
                  print("starting to render")
                  result = c4d.documents.RenderDocument(
                      docClone, rd.GetData(), bmPreview, c4d.RENDERFLAGS_EXTERNAL, th=None
                  if result == c4d.RENDERRESULT_OK:
                      filepath = rd[c4d.RDATA_PATH]
                      print(f"filepath: {filepath}")
                      if "$" in filepath:
                          filepath = self.resolve_and_normalize_path(filepath, doc, rd)
                      file_format = rd[c4d.RDATA_FORMAT]
                      print(f"file_format: {file_format}")
                      filepath += self.get_extension_for_format(file_format)
                      print(f"filepath 2: {filepath}, {file_format}")
                      bmPreview.Save(filepath, file_format)
                      self.send_image_to_server(filepath, URL)
                  self.rendering = False
              def resolve_and_normalize_path( self, tokenized_path, doc, rd):
                  # Define the rpData dictionary to resolve tokens
                  rpData = {
                      "_doc": doc,
                      "_rData": rd,
                      "_rBc": rd.GetData(),
                      # "_frame": 2,  # Replace this with the actual frame number if available
                      # Add any other needed data here
                  # Convert the tokens to their actual values
                  filepath = c4d.modules.tokensystem.StringConvertTokens(tokenized_path, rpData)
                  # Check if the filepath is absolute
                  if not os.path.isabs(filepath):
                      # If not, make it absolute
                      base_path = doc.GetDocumentPath()
                      filepath = os.path.join(base_path, filepath)
                  # Normalize the file path to use the standard slashes for your OS
                  filepath = os.path.normpath(filepath)
                  return filepath
      When I render via my plugin in RS, it renders one additional image with different colour settings. file: balls-v010.png in this image: Screenshot 2024-01-27 at 1.49.55 PM.png
      I have looked at https://github.com/PluginCafe/cinema4d_py_sdk_extended/blob/a12cca185a7a07fb20aa34520799b66007839e1e/scripts/05_modules/token_system/tokensystem_render_r17.py#L9 and its super helpful but doesn't help me with the AOVs
      DunhouD 1 Reply Last reply Reply Quote 0
      • DunhouD
        Dunhou @thomas
        Hi @thomas ,
        Here is a little function in my Renderer library, seems like what you want to do, hope it can helps😊
        Cheers~
        DunHou
        AOVs
        Console
        --- REDSHIFTRENDER ---
        Color space: ACEScg
        AOV count: 4
        Type                  :1
        Enabled               :Yes
        Multi-Pass            :Yes
        Direct                :No
        Direct Path           :$filepath$filename_$pass
        Direct Effective Path :
        Type                  :42
        Enabled               :Yes
        Multi-Pass            :Yes
        Direct                :Yes
        Direct Effective Path :Untitled_4_AOV_Cryptomatte.exr
        Type                  :41
        Enabled               :Yes
        Multi-Pass            :Yes
        Direct                :No
        Type                  :23
        Enabled               :Yes
        Multi-Pass            :Yes
        Direct                :No
        Codes
        from Renderer import Redshift
            # Get the doc host the aovs, in this case th active doc
            doc: c4d.documents.BaseDocument = c4d.documents.GetActiveDocument()
            # Set redshift AOVHelper instance
            aov_helper = Redshift.AOV(doc)
            # Print current aov info
            aov_helper.print_aov()
        https://boghma.com
        https://github.com/DunHouGo
        i_mazlovI 1 Reply Last reply Reply Quote 1
        • i_mazlovI
          i_mazlov @Dunhou
          Hi @thomas ,
          There's redshift python API that you can use for that. Please check the sample code snippet below that creates "Depth" AOV and then prints all of the existing AOVs into the console for the active document. I assume in the core @Dunhou uses this exact approach conveniently wrapped by the renderer library.
          Ilia
          The sample code snippet:
          import c4d.documents
          import redshift
          def CreateAOVs(vpRS):
          	aovs = []
          	aov = redshift.RSAOV()
          	aov.SetParameter(c4d.REDSHIFT_AOV_TYPE, c4d.REDSHIFT_AOV_TYPE_DEPTH)
          	aov.SetParameter(c4d.REDSHIFT_AOV_ENABLED, True)
          	aov.SetParameter(c4d.REDSHIFT_AOV_NAME, "My Depth")
          	aovs.append(aov)
          	return redshift.RendererSetAOVs(vpRS, aovs)
          def PrintAOVs(vpRS):
          	aovs = redshift.RendererGetAOVs(vpRS)
          	for aov in aovs:
          		print("-----------------------------------------------------------")
          		print("Name                  :%s" % aov.GetParameter(c4d.REDSHIFT_AOV_NAME))			# The customized name of an AOV
          		print("Effective Name        :%s" % aov.GetParameter(c4d.REDSHIFT_AOV_EFFECTIVE_NAME))	# The customized name of the AOV or a sensible default when empty # Available from 2.6.50/3.0.10
          		print("Type                  :%d" % aov.GetParameter(c4d.REDSHIFT_AOV_TYPE))
          		print("Enabled               :%s" % ("Yes" if aov.GetParameter(c4d.REDSHIFT_AOV_ENABLED) else "No"))
          		print("Multi-Pass            :%s" % ("Yes" if aov.GetParameter(c4d.REDSHIFT_AOV_MULTIPASS_ENABLED) else "No"))
          		print("Direct                :%s" % ("Yes" if aov.GetParameter(c4d.REDSHIFT_AOV_FILE_ENABLED) else "No"))
          		print("Direct Path           :%s" % aov.GetParameter(c4d.REDSHIFT_AOV_FILE_PATH))
          		print("Direct Effective Path :%s" % aov.GetParameter(c4d.REDSHIFT_AOV_FILE_EFFECTIVE_PATH)) # Available from 2.6.44/3.0.05
          	renderdata = doc.GetActiveRenderData()
          	# Get the Redshift videoPost and render settings
          	vprs = redshift.FindAddVideoPost(renderdata, redshift.VPrsrenderer)
          	if vprs is None:
          	# Switch renderer
          	renderdata[c4d.RDATA_RENDERENGINE] = redshift.VPrsrenderer
          	CreateAOVs(vprs)
          	PrintAOVs(vprs)
          • T
            thomas
            @Dunhou @i_mazlov, thanks so much both. This really helped.
            Where is the Redshift Python documentation, I tried the normal Redshift online help https://help.maxon.net/r3d/cinema/en-us/#search-python and the python plugin help.
            • i_mazlovI
              i_mazlov @thomas
              Hi @thomas,
              I don't think there's a single place with aggregated Redshift Python API documentation. Such things are usually discussed on redshift forums.
              Ilia
              • T
                thomas
                ok. I know not your department, but thats nuts.
                Thanks!
