    Python Xpresso Node
    windowspython2023
    5 Posts 3 Posters 1.1k Views 1 Watching
    • L Offline
      ll2pakll
      Windows 10
      Cinema 4d 2023.2.1
      Good evening.
      Which command allows you to add a Python Xpresso node?
      I didn't find it in the list of available id's. But without it my program will not work correctly.
      Also, I need to understand how I can put the necessary code into this node for it to work? Or maybe there is a way not to use this node, but to use an alternative?
      This is what the code placed in this node looks like:
      from typing import Optional
      op: c4d.modules.graphview.GvNode # The Xpresso node
      doc: c4d.documents.BaseDocument # The document evaluating this node
      tp: Optional[c4d.modules.thinkingparticles.TP_MasterSystem] # Particle system
          global Output1
          katet_1 = Input1 - Input3
          kater_2 = Input2 - Input4
          kvadrat_giopotenuzy = katet_1**2 + kater_2**2
          Output1 = kvadrat_giopotenuzy**0.5
      • M Online
        Hi you should use ID_OPERATOR_COFFEE, this is mostly due to historical reason since previously the scripting language in Cinema 4D was COFFEE and it was then replaced with Python.
        L B 2 Replies Last reply Reply Quote 1
        • L Offline
          ll2pakll @m_adam
          @m_adam Thank you very much for your reply. But while I was waiting for a reply, I experimented and realized that the Python tag suits me much better than the xpresso system, and rewrote the whole scene overnight). Have a great day.
          • B Offline
            Brakusha @m_adam
            @m_adam said in Python Xpresso Node:
            ID_OPERATOR_COFFEE is not work.(((
            • M Online
              Hi @Brakusha, welcome in plugin cafe !
              c4d.ID_OPERATOR_COFFEE is working in all versions, please open a new topic with a code that demonstrate the issue and with a short explanation about what you want to achieve. I would also highly recommend you to read our Support Guideline to know how to get the best support from us.
