    Adding ports to nodes.
    2023pythonwindows
    3 Posts 2 Posters 1.0k Views 1 Watching
    • L Offline
      ll2pakll
      I apologize for re-creating the post, I forgot to include my system details:
      Windows 10
      Cinema 4d 2023.2.1
      Hi, I'm trying to figure out node creation via script manager and have run into a place I can't get past on my own. I want to create an output port with global data for a node, but I don't understand how to do it. In one of the parameters "GvNode.AddPort(self, io, id, flag=GV_PORT_FLAG_IS_VISIBLE, message=False)" I need to enter id, but I don't understand where I can see the id I need. Please tell me how to add ports to nodes correctly, and if possible, tell me how to connect them. Thank you very much. Here is my code:
      cube1 = c4d.BaseObject(c4d.Ocube)
      cube1.SetName('Куб 1')
      cube2 = c4d.BaseObject(c4d.Ocube)
      cube2.SetName('Куб 2')
      doc.InsertObject(cube1)
      doc.InsertObject(cube2)
      xpresso = c4d.modules.graphview.XPressoTag()
      cube1.InsertTag(xpresso)
      NodeMaster = xpresso.GetNodeMaster()
      node_1 = NodeMaster.CreateNode(NodeMaster.GetRoot(), c4d.ID_OPERATOR_OBJECT)
      node_2 = NodeMaster.CreateNode(NodeMaster.GetRoot(), c4d.ID_OPERATOR_OBJECT, x=100)
      node_1.AddPort(c4d.GV_PORT_OUTPUT, 1, c4d.GV_PORT_FLAG_IS_VISIBLE)
      node_2.OperatorSetData(c4d.GV_ATOM, cube2, c4d.GV_OP_DROP_IN_BODY)
        ferdinand @ll2pakll
        Hello @ll2pakll ,
        Welcome to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!
        Getting Started
        Before creating your next postings, we would recommend making yourself accustomed with our Forum and Support Guidelines, as they line out details about the Maxon SDK Group support procedures. Of special importance are:
        • Support Procedures: Scope of Support: Lines out the things we will do and what we will not do.
        • Support Procedures: Confidential Data: Most questions should be accompanied by code but code cannot always be shared publicly. This section explains how to share code confidentially with Maxon.
        • Forum Structure and Features: Lines out how the forum works.
        • Structure of a Question: Lines out how to ask a good technical question. It is not mandatory to follow this exactly, but you should follow the idea of keeping things short and mentioning your primary question in a clear manner.
        About your First Question
        Please avoid deleting posts in the future. You got things almost right, but seem to struggle a bit with the concept of DescID. Find my answer below.
        I would also recommend having a look at these resources:
        • Graphview Examples on GitHub
        • Details on DescID
        Result:
        Code:
        """Demonstrates how to create a port on a graph node and how to connect two nodes.
        See [1] for an overview of the graphview module and [2] for details on DescID.
        References:
            [1] https://github.com/PluginCafe/cinema4d_py_sdk_extended/tree/master/scripts/05_modules/xpresso
            [2] https://developers.maxon.net/forum/topic/13517/how-to-add-a-userdata-child-to-a-group-via-script
        from c4d.modules import graphview as gv
        doc: c4d.documents.BaseDocument
            # Create and name the two objects.
            cubeA: c4d.BaseObject = c4d.BaseObject(c4d.Ocube)
            cubeB: c4d.BaseObject = c4d.BaseObject(c4d.Ocube)
            doc.InsertObject(cubeA)
            doc.InsertObject(cubeB)
            cubeA.SetName("A")
            cubeB.SetName("B")
            # Create the tag, get the node master and the root of the Xpresso graph.
            tag: c4d.BaseTag = cubeA.MakeTag(c4d.Texpresso)
            master: gv.GvNodeMaster = tag.GetNodeMaster()
            root: gv.GvNode = master.GetRoot()
            # You said that you want to "create an output port with global data for a node". That is very
            # ambivalent or not possible. You cannot create a port for arbitrary data on a GvNode. You can
            # only create ports for the parameters a node holds. In the case of an object node also the
            # parameters of the scene element it wraps. The parameters are referenced via DescIDs and in
            # case of creating ports we must be quite precise. See [2] for details on the subject.
            # The parameter ID for the editor visibility of an object. We will use it both for the in and
            # output port, because they both target the same parameter.
            did: c4d.DescID = c4d.DescID(
                c4d.DescLevel(c4d.ID_BASEOBJECT_VISIBILITY_EDITOR, # ID of the element.
                              c4d.DTYPE_LONG,                      # Its data type, an integer.
                              0))                                  # The creator, the correct value would be
        # Ocube or cubeA.GetType(), but 0, i.e.,
        # undefined also works here.
            # Create the two nodes and set the referenced objects. When setting the references we do not
            # have to be as precise as when defining ports with our IDs.
            nodeA: gv.GvNode = master.CreateNode(root, c4d.ID_OPERATOR_OBJECT)
            nodeB: gv.GvNode = master.CreateNode(root, c4d.ID_OPERATOR_OBJECT, x=200)
            nodeA[c4d.GV_OBJECT_OBJECT_ID] = cubeA
            nodeB[c4d.GV_OBJECT_OBJECT_ID] = cubeB
            # Add an input and output port.
            outPort: gv.GvPort = nodeA.AddPort(c4d.GV_PORT_OUTPUT, did, c4d.GV_PORT_FLAG_IS_VISIBLE)
            inPort: gv.GvPort = nodeB.AddPort(c4d.GV_PORT_INPUT, did, c4d.GV_PORT_FLAG_IS_VISIBLE)
            # And connect them.
            outPort.Connect(inPort)
        L 1 Reply Last reply Reply Quote 1
        • L Offline
          ll2pakll @ferdinand
          @ferdinand said in Adding ports to nodes.:
          DescID
          Thank you so much. I am pleasantly surprised at the level of your responsiveness. When I wrote "Global Data" I accidentally used the wrong word, I meant "Global Coordinates". I have read your links and code very carefully. Actually the concept of DescID is not so much complicated as confusing, the easiest thing would be to have something like an interactive online converter that could show the attributes of the desired objects and their corresponding id. I will try to understand the concept of DescID, deeper. And thank you again for your very detailed answer. Have a nice day.
