    ShowBitmap() and image name
    sdkc++
    5 Posts 2 Posters 1.6k Views 1 Watching
    • WickedPW Offline
      WickedP
      Hi folks,
      How do I set a name for an image sent to the picture viewer? This bit here:
      I tried setting the bitmap data like this:
      bmp->SetData(BASEBITMAP_DATA_NAME,"My name");
      ShowBitmap(bmp);
      but it does nothing.
      WP.
      wickedp.com
        ferdinand @WickedP
        Hello @WickedP,
        thank you for reaching out to us. I noticed this too a while ago, and there is a ticket for that in the SDK task pool. It, however, has low priority.
        • ShowBitmap has a backend implementation of the same name which takes in a string to name the bitmap.
        • The backend ignores all bitmap metadata and the frontend version of ShowBitmap does not support the name argument.
        There is also the file lib_pictureviewer.h in frameworks/cinema.framework/source/c4d_libs/ which deliberately has been hidden from the C++ documentation. It contains an interface for the picture viewer which provides more control, including displaying a bitmap with a user chosen name, PictureViewer::ShowImage.
        So, you will not find this file in our online- or offline documentation, and instead must read the header file yourself. I frankly have no clue why that file has been hidden in the first place. Long story short, tread with care here, lib_pictureviewer.h is not officially supported. But I do not see what here should be going wrong for you as this interface just wraps an internal interface which is used all the time by us. And I also know of quite a few third parties using this (semi) public interface.
        PS: I gave the ShowBitmap task a little nudge by adding this topic as a ressource, but it is still low priority, so it might take a while before we get to it.
        • WickedPW Offline
          WickedP
          Hi @ferdinand,
          I seem to have something working with the lib_pictureviewer.h library. Thanks for this. Maybe in future the standard ShowBitmap() could have a default empty string argument with it. Just a thought.
          Thanks again,
          WP.
          wickedp.com
          WickedPW 1 Reply Last reply Reply Quote 0
          • WickedPW Offline
            WickedP @WickedP
            @ferdinand, By the way, just a small forum issue I'm seeing, I noticed my 'Mark as solved' doesn't look right in the menu. Don't know if it's just me or if the css might need some attention?
            Thanks again.
            WP.
            wickedp.com
              ferdinand @WickedP
              Hey @WickedP,
              Thank you for pointing it out. There was a problem with how the CSS of the plugin providing the solved feature, the forum CSS, and our styling CSS did mesh in the light skin. I fixed it by putting even more CSS on top of things - because who doesn't love a solid mess in the CSS 😛
              PS: I am aware that the search feature could also still use some work under the dark skin. It is just not the highest priority when things are ugly but readable.
