<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ShowBitmap() and image name]]></title><description><![CDATA[<p dir="auto">Hi folks,</p>
<p dir="auto">How do I set a name for an image sent to the picture viewer? This bit here:</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1691815238734-93084c00-cd80-473f-96e0-6d0be847f487-image.png" alt="93084c00-cd80-473f-96e0-6d0be847f487-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I tried setting the bitmap data like this:</p>
<pre><code>bmp-&gt;SetData(BASEBITMAP_DATA_NAME,"My name");
ShowBitmap(bmp);
</code></pre>
<p dir="auto">but it does nothing.</p>
<p dir="auto">WP.</p>
]]></description><link>http://developers.maxon.net/forum/topic/14946/showbitmap-and-image-name</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 10:40:52 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/14946.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Aug 2023 04:43:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ShowBitmap() and image name on Thu, 17 Aug 2023 11:56:36 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/wickedp">@<bdi>WickedP</bdi></a>,</p>
<p dir="auto">Thank you for pointing it out. There was a problem with how the CSS of the plugin providing the solved feature, the forum CSS, and our styling CSS did mesh in the light skin. I fixed it by putting even more CSS on top of things - because who doesn't love a solid mess in the CSS <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61b.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--stuck_out_tongue" style="height:23px;width:auto;vertical-align:middle" title=":P" alt="😛" /></p>
<p dir="auto">PS: I am aware that the search feature could also still use some work under the dark skin. It is just not the highest priority when things are ugly but readable.</p>
<p dir="auto">Cheers,<br />
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/72269</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72269</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Thu, 17 Aug 2023 11:56:36 GMT</pubDate></item><item><title><![CDATA[Reply to ShowBitmap() and image name on Thu, 17 Aug 2023 10:29:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a>, By the way, just a small forum issue I'm seeing, I noticed my 'Mark as solved' doesn't look right in the menu. Don't know if it's just me or if the css might need some attention?</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1692268095765-1ebc9c69-f3f7-47c0-b13f-bb5a184c9f58-image.png" alt="1ebc9c69-f3f7-47c0-b13f-bb5a184c9f58-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thanks again.</p>
]]></description><link>http://developers.maxon.net/forum/post/72266</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72266</guid><dc:creator><![CDATA[WickedP]]></dc:creator><pubDate>Thu, 17 Aug 2023 10:29:00 GMT</pubDate></item><item><title><![CDATA[Reply to ShowBitmap() and image name on Thu, 17 Aug 2023 10:25:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a>,</p>
<p dir="auto">I seem to have something working with the lib_pictureviewer.h library. Thanks for this. Maybe in future the standard ShowBitmap() could have a default empty string argument with it. Just a thought.</p>
<p dir="auto">Thanks again,</p>
]]></description><link>http://developers.maxon.net/forum/post/72265</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72265</guid><dc:creator><![CDATA[WickedP]]></dc:creator><pubDate>Thu, 17 Aug 2023 10:25:34 GMT</pubDate></item><item><title><![CDATA[Reply to ShowBitmap() and image name on Mon, 14 Aug 2023 08:56:06 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/wickedp">@<bdi>WickedP</bdi></a>,</p>
<p dir="auto">thank you for reaching out to us. I noticed this too a while ago, and there is a ticket for that in the SDK task pool. It, however, has low priority.</p>
<ul>
<li><code>ShowBitmap</code> has a backend implementation of the same name which takes in a string to name the bitmap.</li>
<li>The backend ignores all bitmap metadata and the frontend version of <code>ShowBitmap</code> does not support the name argument.</li>
</ul>
<p dir="auto">There is also the file <code>lib_pictureviewer.h</code> in <code>frameworks/cinema.framework/source/c4d_libs/</code> which deliberately has been hidden from the C++ documentation. It contains an interface for the picture viewer which provides more control, including displaying a bitmap with a user chosen name, <code>PictureViewer::ShowImage</code>.</p>
<p dir="auto">So, you will not find this file in our online- or offline documentation, and instead must read the header file yourself. I frankly have no clue why that file has been hidden in the first place. Long story short, tread with care here, <code>lib_pictureviewer.h</code> is not officially supported. But I do not see what here should be going wrong for you as this interface just wraps an internal interface which is used all the time by us. And I also know of quite a few third parties using this (semi) public interface.</p>
<p dir="auto">PS: I gave the <code>ShowBitmap</code> task a little nudge by adding this topic as a ressource, but it is still low priority, so it might take a while before we get to it.</p>
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/72237</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72237</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Mon, 14 Aug 2023 08:56:06 GMT</pubDate></item></channel></rss>
