    How to get a port data type?
    sdkpythonwindows2023
    6 Posts 3 Posters 2.0k Views 2 Watching
    • DunhouD Offline
      Dunhou
      Hi community!
      Questions:
      How can I get the datetype of a selected port(GraphNode)?
      Problem:
      I want to get a type of a maxon.GraphNode aka a port type. Like picture below, I select three port with very basic port type, and I wang to get the type of the port to do some further conditions, but I have trouble with this task.
      I didn't find a api looks like build for this task , I try to get it with the codes and return like this, I can get color/ metalness which had a default value, but not the bump port. (the type returned is not like the GUI, but it can work.)
      Color port
      Name: standardmaterial@WO3Q2uk5Kp4pRHlNJ_Douc<com.redshift3d.redshift4c4d.nodes.core.standardmaterial.base_color
      Value: 0.21404114365577698,0.21404114365577698,0.21404114365577698
      Type: net.maxon.parametrictype.col<3,float64>
      Metalness port
      Name: standardmaterial@WO3Q2uk5Kp4pRHlNJ_Douc<com.redshift3d.redshift4c4d.nodes.core.standardmaterial.metalness
      Value: 0
      Type: float64
      Codes:
      import maxon
          mat = doc.GetActiveMaterial()
          nodeMaterial = mat.GetNodeMaterialReference()
          nodespaceId = c4d.GetActiveNodeSpaceId()
          graph = nodeMaterial.GetGraph(nodespaceId)
          def GetName(node):
              if node is None:
                  return None
              nodeName = node.GetValue(maxon.NODE.BASE.NAME)
              if nodeName is None:
                  nodeName = node.GetValue(maxon.EffectiveName)
                  nodeName = str(node)
              return nodeName
          def RetrieveInformationOfPort(port):
              if port is None:
              portName = GetName(port)
              portValue = port.GetDefaultValue()
              print(f"Name: {portName}")
              print(f"Value: {portValue}")
              print(f"ID: {port.GetId()}")
              print(f"Type: {portValue.GetType().GetId()}")
          maxon.GraphModelHelper.GetSelectedNodes(graph, maxon.NODE_KIND.PORT_MASK, RetrieveInformationOfPort)
      Thanks for your times.
      Cheers~
      https://boghma.com
      https://github.com/DunHouGo
        ferdinand @Dunhou
        Hello @Dunhou,
        Thank you for reaching out to us. In C++, you would retrieve the attribute maxon::nodes::PortType (id: "type") on the node. There are also some attributes of similar purpose which return a maxon::DataType for a GraphNode.
        However, none of these work, because there is a bug in maxon.DataType (i.e., the Python API reflection of maxon::DataType). Currently there is nothing you can do from the Python side of things to fix this. I have filed a bug report and flagged this thread as to_fix.
        Result:
        GetName(port) = 'standardmaterial@Hg9$KeW8OFNmebDk8jn99C<com.redshift3d.redshift4c4d.nodes.core.standardmaterial.bump_input'
        port.GetId() = maxon.InternedId('com.redshift3d.redshift4c4d.nodes.core.standardmaterial.bump_input')
        <class 'maxon.datatype.DataType'> <NativePyData (net.maxon.datatype.datatype) [dt=0x00007FF7EC8692C0,data=0x000001A756F0A370,owner=false] object at 0x000001A756F0A340>
        <class 'maxon.datatype.DataType'> <NativePyData (net.maxon.datatype.datatype) [dt=0x00007FF7EC8692C0,data=0x000001A756F02770,owner=false] object at 0x000001A756F02740>
        <class 'maxon.datatype.DataType'> <NativePyData (net.maxon.datatype.datatype) [dt=0x00007FF7EC8692C0,data=0x000001A756F16670,owner=false] object at 0x000001A756F16640>
        Code:
        def RetrieveInformationOfPort(port: maxon.GraphNode) -> bool:
            if not isinstance(port, maxon.GraphNode):
                return False
            print (f"\n{'-' * 100}")
            print(f"{GetName(port) = }")
            print(f"{port.GetId() = }")
            # Try out various node attributes that express a type.
            for aid in ("type", "fixedtype", "synthesizedtype", "net.maxon.node.deducedtype"):
                # We can get these attributes, but they all return malformed data. There is a
                # bug in maxon.DataType itself (the type of all of these attributes).
                attribute: maxon.Data = port.GetValue(maxon.InternedId(aid))
                if attribute is None:
                    continue
                print (type(attribute), attribute._data)
                # All these lines will fail, because #attribute is malformed in the Python API,
                # its field DataType._data is not what it should be.
                # print(attribute)
                # print(attribute.GetId()) # This would be data type of the port.
        DunhouD 1 Reply Last reply Reply Quote 0
        • DunhouD Offline
          Dunhou @ferdinand
          @ferdinand thanks for your response.
          Then only I can do now maybe pick a manual list with bump and displacement<vector> type port and considering with their ids.hope this will be fixed soon.
          Cheers~
          https://boghma.com
          • J Offline
            jana @Dunhou
            Hello @Dunhou ,
            without further questions or postings, we will consider this topic as solved by Friday, the 11th of august 2023 and flag it accordingly.
            Maxon SDK Group
            • DunhouD Offline
              Dunhou @jana
              @jana Hey, I think this problem is not fixed now, I just test it with R2023.2.2.
              https://boghma.com
              • J Offline
                jana @Dunhou
                Hello @Dunhou ,
                you are correct, the issue is not fixed yet. As Ferdinand mentioned in the beginning he has flagged it as "to_fix", so it will be fixed as soon as possible.
                Thanks and Cheers
                Maxon SDK Group
                • maxonM maxon moved this topic from Cinema 4D SDK on
