    Updating a spline
    3 Posts 2 Posters 1.2k Views 1 Watching
    • KantroninK Offline
      Kantronin
      Hi
      How to update a spline if the number of points changes ?
      If the number of points is the same, we can use the following function:
      def spline_update(spline,tabPoint):
      	dim = len(tabPoint)
      	for i in range(0,dim):
      		spline.SetPoint(i,tabPoint[i])
      	spline.Message(c4d.MSG_UPDATE)
      	return spline
      If the number of points changes, we must use the ResizeObject() method
      I'm looking for an example, which will save me from doing tests.
      • ferdinandF ferdinand moved this topic from General Talk on
        ferdinand @Kantronin
        Hello @Kantronin,
        I have moved your topic due to being in the wrong forum. You might want to look at our geometry_splineobject_s26.py example, as it demonstrates all fundamental aspects of the type, including resizing it.
        KantroninK 1 Reply Last reply Reply Quote 0
          Kantronin @ferdinand
          I made this function which works fine:
          def spline_update(doc,spline,tabNewPoint):
          	tabPoint = spline.GetAllPoints()
          	dim = len(tabNewPoint)
          	if len(tabPoint) != dim:
          		spline.ResizeObject(dim)
          		point = tabNewPoint[i]
          		spline.SetPoint(i,point)
          	return spline
