    GetMg() doesn't update on objects affected with Align to Spline Tag?
    python2023
    3 Posts 2 Posters 1.1k Views
    • B Offline
      bentraje
      I have an object that is constrainted to a spline through align to spline tag.
      The problem is when I run a GetMg().off on before and after I revise the tag, I get the same result instead of having different values.
      What am I missing? šŸ˜ž
          joint = c4d.BaseObject(1019362)
          doc.InsertObject(joint)
          spline = c4d.BaseObject(5181)
          doc.InsertObject(spline)
          spline_tag = c4d.BaseTag(5699)
          joint.InsertTag(spline_tag)
          spline_tag[c4d.ALIGNTOSPLINETAG_LINK] = spline
          spline_tag[c4d.ALIGNTOSPLINETAG_POSITION] = 0
          print (joint.GetMg().off) # Vector(0, 0, 0)
          spline_tag[c4d.ALIGNTOSPLINETAG_POSITION] = 0.2
          print (joint.GetMg().off) # still Vector(0, 0, 0)
      • i_mazlovI Offline
        i_mazlov
        Hi @bentraje,
        you're doing everything right. The only step you're missing is to reevaluate the scene using ExecutePasses after changing the Align to Spline tag position. You can call it the following way:
        doc.ExecutePasses(None, True, True, True, c4d.BUILDFLAGS_NONE)
        Note, you should use c4d.BUILDFLAGS_0 instead, if you run c4d earlier than R20. This is how you can use it in a generic way:
        buildFlag = c4d.BUILDFLAGS_NONE if c4d.GetC4DVersion() > 20000 else c4d.BUILDFLAGS_0
        doc.ExecutePasses(None, True, True, True, buildFlag)
        Ilia
        • B Offline
          bentraje
          @i_mazlov
          Gotcha. Thanks. Works as expected.
