    Displaying tag properties as part of object's properties
    c++maxon apisdk
    3 Posts 2 Posters 1.2k Views 1 Watching
    • yesbirdY Offline
      yesbird
      Could you please suggest me, how to make tag info available in object's properties, like here:
      By default, tag properties are displayed separately, only when tag is selected.
      Thanks in advance,
      Sergey (Yesbird).
      YB
        if you defined TAG_MULTIPLE when you register your tag, the tag will not be displayed in the attribut manager when you select the object.
        Other than that, i did not found anything special to do.
        With the latest version (i think it was introduced in r25) you have a parameter on each tag to expose the tag on the object ID_EXPOSETAB that must be set to true.
        yesbirdY 1 Reply Last reply Reply Quote 0
        • yesbirdY Offline
          yesbird @Manuel
          Thanks, @Manuel.
          The reason was in definition of TAG_MULTIPLE at the moment of registration. Now the tag properties are displayed as I was expecting.
          YB
          YB
