    How to detect CTRL being pressed in a GeDialog
    Cinema 4D SDK
    r23 r25 2023 c++
    • C4DSC
      C4DS
      I am in a GeDialog and have a button that is by default disabled.
      I want to enable it as long as CTRL key is being pressed.
      • C4DSC
        C4DS
        The following works in R20
        Int32 MyDialog::Message(const BaseContainer& msg, BaseContainer& result)
        	BaseContainer keyChannels;
        	if (GetInputEvent(BFM_INPUT_KEYBOARD, keyChannels))
        		const Int32 qualifier = keyChannels.GetInt32(BFM_INPUT_QUALIFIER);
        		ApplicationOutput("qualifier @", qualifier);
        It shows a value '2' when I press CTRL key, '0' when I let go.
        But in R23 (and above), I don't get any output in console window.
        • M
          Hi @C4DS this has indeed changed, I will check with the UI team to know the exact reason. To retrieve qualifier I find out that only GetInputState is working, so in the meantime you can do this like that and it work as expected
              def Message(self, msg, result):
                  res = c4d.BaseContainer()
                  self.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.QCTRL, res)
                  if res[c4d.BFM_INPUT_QUALIFIER]:
                      print(msg.GetId())
                      isShiftPressed = bool(res[c4d.BFM_INPUT_QUALIFIER] & c4d.QSHIFT)
                      isCtrlPressed = bool(res[c4d.BFM_INPUT_QUALIFIER] & c4d.QCTRL)
                      isAltPressed = bool(res[c4d.BFM_INPUT_QUALIFIER] & c4d.QALT)
                      print(f"{isShiftPressed=}, {isCtrlPressed=}, {isAltPressed=}")
                      print("----------------------------")
                  return c4d.gui.GeDialog.Message(self, msg, result)
          • C4DSC
            C4DS
            Thanks @m_adam
            I can confirm that the following does work with R20, R23 and 2023
            	if (GetInputState(BFM_INPUT_KEYBOARD, QCTRL, keyChannels))
            		Bool ctrlModifier = (keyChannels.GetInt32(BFM_INPUT_QUALIFIER) & QCTRL) != 0;
            • M m_adam referenced this topic on
