    Setting Material Preview for 1 material
    2023python
    3 Posts 2 Posters 727 Views 1 Watching
    • P Offline
      pim
      I know it is possible to set the material preview in Preferences by
      Material[c4d.PREF_MM_MATSCENE] = 2000001008 #Flat projection
      When I try to do this for a single material, it is not working.
      What am I doing wrong?
      from typing import Optional
      doc: c4d.documents.BaseDocument # The active document
      op: Optional[c4d.BaseObject] # The active object, None if unselected
          mat = doc.GetActiveMaterial()
          print (mat.GetName(), mat[c4d.PREF_MM_MATSCENE])
          mat[c4d.PREF_MM_MATSCENE] = 2000001008    #Flat projection
          mat.Update(True, True)
      PS How can I set a post to 'Solved"?
        If you want to change the default material preview scene, the one in the preferences, you must do the following.
            wc = c4d.GetWorldContainerInstance()
            wc[c4d.WPREF_MATPREVIEW_DEFAULTOBJECT_MAT] = c4d.MatPreviewSphere
        The ID that needs to be used can be found here. We have a code that will add 2000000000 to this value if the value is lower than MatPreviewUser (1050). If i remember correctly, users were able to add their own scene preview. With the nodematerial this is not possible anymore.
        If you want to change the material preview of a standard material, you must retrieve the material preview data of the material. Unfortunately, this DataType is not implemented in python so this is not possible.
        It is possible to change the value of this preview in the preferences and create the material, but it doesn't work if you set back the value that was defined.
            saveValue  = wc[c4d.WPREF_MATPREVIEW_DEFAULTOBJECT_MAT]
            material = c4d.BaseMaterial(c4d.Mmaterial)
            doc.InsertMaterial(material)
            # this line will make the material preview modification not working
            # wc[c4d.WPREF_MATPREVIEW_DEFAULTOBJECT_MAT] = saveValue
        The question about marking a thread as solved, you can have a look at our forum guidelines
        • P Offline
          pim
          Thank you.
