    TreeView for ObjectData plugin
    pythonr23
    2 Posts 2 Posters 717 Views 2 Watching
    • mikeudinM Offline
      mikeudin
      Hello!
      Can't figure out how to add TreeView gui to ObjectData attributes interface.
      There is some tips here, but is not clear how it can be used in python.🤷‍♂️
      Here is a sample code what i want to implement.
      testgen.zip
      /res/description/Otestgen.h
      enum {
          Otestgen = 100500,
          TG_TEST_GROUP = 1000,
          TG_TAGSGROUP_GROUP = 1001,
          TG_TAGS = 1002,
      /res/description/Otestgen.res
      CONTAINER Otestgen {
          INCLUDE Obase;
          NAME Otestgen;
          GROUP ID_OBJECTPROPERTIES {
          GROUP TG_TEST_GROUP {
              DEFAULT 1;
              GROUP TG_TAGSGROUP_GROUP {
                  DEFAULT 1;
                  ITEMTREE TG_TAGS { }
      /res/strings_us/description/Otestgen.str
      STRINGTABLE Otestgen {
          Otestgen "TestGen";
          TG_TEST_GROUP "Test";
          TG_TAGSGROUP_GROUP "";
          TG_TAGS "Tags";
      /testgen.pyp
      import os
      def load_bitmap(path):
          path = os.path.join(os.path.dirname(__file__), path)
          if bmp.InitWith(path)[0] != c4d.IMAGERESULT_OK:
              bmp = None
          return bmp
      class tagObject(object):
          Class which represent a texture, aka an Item in our list
          name = "Default"
          _checked = True
          _selected = False
          def __init__(self, name):
              self.name = name
          @property
          def IsSelected(self):
              return self._selected
          def Select(self):
              self._selected = True
          def Deselect(self):
              self._selected = False
          def __repr__(self):
              return str(self)
          def __str__(self):
              return self.name
      class ListView(c4d.gui.TreeViewFunctions):
          def __init__(self):
              self.tagList = list() # Store all objects we need to display in this list
          def IsResizeColAllowed(self, root, userdata, lColID):
          def IsTristate(self, root, userdata):
              return False
          def GetColumnWidth(self, root, userdata, obj, col, area):
              if col == ID_NAME:
                  return 200
              return 80  # All have the same initial width
          def IsMoveColAllowed(self, root, userdata, lColID):
              # The user is allowed to move all columns.
              # TREEVIEW_MOVE_COLUMN must be set in the container of AddCustomGui.
              return False
          def GetFirst(self, root, userdata):
              Return the first element in the hierarchy, or None if there is no element.
              rValue = None if not self.tagList else self.tagList[0]
              return rValue
          def GetNext(self, root, userdata, obj):
              Returns the next Object to display after arg:'obj'
              rValue = None
              pList = self.tagList
              currentObjIndex = pList.index(obj)
              nextIndex = currentObjIndex + 1
              if nextIndex < len(pList):
                  rValue = pList[nextIndex]
              return rValue
          def GetPred(self, root, userdata, obj):
              Returns the previous Object to display before arg:'obj'
              nextIndex = currentObjIndex - 1
          def GetId(self, root, userdata, obj):
              Return a unique ID for the element in the TreeView.
              return hash(obj)
          def Select(self, root, userdata, obj, mode):
              Called when the user selects an element.
              if mode == c4d.SELECTION_NEW:
                  for preset in self.tagList:
                      preset.Deselect()
                  obj.Select()
              elif mode == c4d.SELECTION_ADD:
                  obj.Select()
              elif mode == c4d.SELECTION_SUB:
                  obj.Deselect()
          def IsSelected(self, root, userdata, obj):
              Returns: True if *obj* is selected, False if not.
              return obj.IsSelected
          def SetCheck(self, root, userdata, obj, column, checked, msg):
              Called when the user clicks on a checkbox for an object in a
              `c4d.LV_CHECKBOX` column.
              if checked:
                  obj.checked = True
                  obj.checked = False
          def IsChecked(self, root, userdata, obj, column):
              Returns: (int): Status of the checkbox in the specified *column* for *obj*.
              if obj.checked:
                  return c4d.LV_CHECKBOX_CHECKED | c4d.LV_CHECKBOX_ENABLED
                  return c4d.LV_CHECKBOX_ENABLED
          def GetName(self, root, userdata, obj):
              Returns the name to display for arg:'obj', only called for column of type LV_TREE
              return str(obj) # Or obj.presetType
          def SetName(self, root, userdata, obj, name):
              obj.name = name
          def ContextMenuCall(self, root, userdata, obj, lColumn, lCommand):
              The user executes an entry of the context menu.
              Returns:
                  (bool): True if the event was handled, False if not.
              if lCommand == c4d.ID_TREEVIEW_CONTEXT_RESET:
                  print ('Call Reset')
              if lCommand == c4d.ID_TREEVIEW_CONTEXT_REMOVE:
                  print ('Call Remove All')
          def DoubleClick(self, root, userdata, obj, col, mouseinfo):
              Called when the user double-clicks on an entry in the TreeView.
              Returns:
                (bool): True if the double-click was handled, False if the
                  default action should kick in. The default action will invoke
                  the rename procedure for the object, causing `SetName()` to be
                  called.
              return False
          def DeletePressed(self, root, userdata):
              """Called when a delete event is received."""
              for preset in reversed(self.tagList):
                  if preset.IsSelected:
                      self.tagList.remove(preset)
                      continue
      class TestGenData(c4d.plugins.ObjectData):
          PLUGIN_ID = 100500 #Example PLUgiN Id
          PLUGIN_NAME = 'TestGen'
          PLUGIN_INFO = c4d.OBJECT_GENERATOR
          PLUGIN_DESC = 'Otestgen'
          PLUGIN_ICON = load_bitmap('res/icons/TestGen.tiff')
          PLUGIN_DISKLEVEL = 0
          # TreeView Column IDs.
          ID_CHECKBOX = 1
          ID_NAME = 2
          @classmethod
          def Register(cls):
              return c4d.plugins.RegisterObjectPlugin(
                  cls.PLUGIN_ID, cls.PLUGIN_NAME, cls, cls.PLUGIN_DESC, cls.PLUGIN_INFO,
                  cls.PLUGIN_ICON, cls.PLUGIN_DISKLEVEL)
          def __init__(self):
              self.SetOptimizeCache(True)
          def Init(self, node):
              self.InitAttr(node, c4d.TreeViewCustomData, [res.TG_TAGS]) # How to Inint this CustomDataType attribute??
          def GetDDescription(self, node, description, flags):
              # Before adding dynamic parameters, load the parameters from the description resource
              if not description.LoadDescription(node.GetType()):
                  return False
              singleID = description.GetSingleDescID()
              myTreeID = c4d.DescID(c4d.TG_TAGS)
              # This is a way i think how to add TreeView to attributes. But how to connect TreeView class object to it?
              if singleID is None or myTreeID.IsPartOf(singleID)[0]:
                  # Add dynamic parameter
                  bc = c4d.GetCustomDataTypeDefault(c4d.CUSTOMGUI_TREEVIEW)
                  bc.SetInt32(c4d.DESC_CUSTOMGUI, c4d.CUSTOMGUI_TREEVIEW)
                  bc.SetString(c4d.DESC_NAME, "Animators")
                  bc.SetString(c4d.DESC_SHORT_NAME, "Animators");
                  bc.SetLong(c4d.DESC_ANIMATE, c4d.DESC_ANIMATE_OFF);
                  bc.SetBool(c4d.TREEVIEW_OUTSIDE_DROP, False)
                  bc.SetBool(c4d.TREEVIEW_HAS_HEADER, True)
                  bc.SetBool(c4d.TREEVIEW_BORDER, c4d.BORDER_THIN_IN)
                  bc.SetBool(c4d.TREEVIEW_HAS_HEADER, False) # True if the tree view may have a header line.
                  bc.SetBool(c4d.TREEVIEW_HIDE_LINES, False) # True if no lines should be drawn.
                  bc.SetBool(c4d.TREEVIEW_MOVE_COLUMN, True) # True if the user can move the columns.
                  bc.SetBool(c4d.TREEVIEW_RESIZE_HEADER, False) # True if the column width can be changed by the user.
                  bc.SetBool(c4d.TREEVIEW_FIXED_LAYOUT, True) # True if all lines have the same height.
                  bc.SetBool(c4d.TREEVIEW_ALTERNATE_BG, True) # Alternate background per line.
                  bc.SetBool(c4d.TREEVIEW_CURSORKEYS, True) # True if cursor keys should be processed.
                  bc.SetBool(c4d.TREEVIEW_NOENTERRENAME, False) # Suppresses the rename popup when the user presses enter.
                  bc.SetBool(c4d.TREEVIEW_NO_MULTISELECT, True)
                  # Add TREEVIEW to the parameters in specified group
                  if not description.SetParameter(myTreeID, bc, c4d.DescID(c4d.TG_TAGSGROUP_GROUP)): # group ID from above post
                      return False
          def GetVirtualObjects(self, op, hh):
              return c4d.BaseObject(c4d.Ocube)
          TestGenData.Register()
      https://mikeudin.net
        Hi Mike this is unfortunately not possible, even in C++ for more info please look at Info for ITEMTREE/customgui_itemtree.
