    Set PYP file syntax highlighting in VS Code?
    General Talk
    r25 python
    • B
      bentraje
      I'm probably missing something so obvious but when I open a .pyp file in VS Code. It is not recognize as a python file. Syntax highlighting does not work.
      Is there a way to set-it as a python file?
      Tried searching google but couldnt' find any relevant info.
      Pretty please? 😞
      • M
        How to make VS Code treat a file extensions as a certain language?
        B 1 Reply Last reply Reply Quote 0
        • B
          bentraje @m_adam
          @m_adam
          Gotcha. Thanks for the link.
          Works as expected.
          Just a heads up.
          ".pyp": "py" doesn't work.
          Need to specify the actual language
          "*.pyp": "python"
          • M
            Btw if you install the Cinema 4D Vs Code extension, pyp extension should be added as Python.
            • i_mazlovI i_mazlov referenced this topic on
