    Switch render engine to Redshift (In memory)
    4 Posts 3 Posters 975 Views 2 Watching
    • J Offline
      jwzegelaar
      Hi Guys,
      I prepared a scene in memory and like to render this now with Redshift. To do this I need to switch from the standard render engine to Redshift.
      A simple:
      rd = doc.GetActiveRenderData()
      rdata[c4d.RDATA_RENDERENGINE] = 1036219
      Is not working and it will just use the Standard render engine, I think because I need to set the VideoPost.
      I can get this by using:
      def GetRedshift(rd):
          rs = rd.GetFirstVideoPost()
          while rs and rs.GetType() != 1036219:
              rs = rs.GetNext()
          return rs
      And trying to set it with InsertVideoPost but no luck. Maybe I'm completely on the wrong path.
      Can anybody help me do this.
      Thank you!😊
        Hi you need to insert the video post as shown in the C++ manual - Redshift Renderer - Set Render Engine to Redshift, adapting it to Python should be pretty straightforward.
        Have a nice weekend.
        • J Offline
          jwzegelaar
          Thank you Maxime!
          This was the part I needed, i was looking in the right direction. 🙂
          redshiftVideoPost = c4d.documents.BaseVideoPost(PID_REDSHIFT_RENDER_ENGINE)
                      print("RedshiftVideoPost: ", redshiftVideoPost)
                      # Insert the Redshift video post plugin.
                      rdata.InsertVideoPost(redshiftVideoPost)
          Have a great weekend!
            ferdinand @jwzegelaar
            Hi @everyone,
            just as an FYI, the example is slightly outdated. With 2023.0.0 or newer, there is no need to manually define a symbol for the Redshift renderer, as one can use the newly exposed VPrsrenderer symbol (c4d.VPrsrenderer in Python).
            I have updated the C++ example.
