    CreateRepositoryFromUrl results in TypeError in 2023
    python2023
    4 Posts 2 Posters 860 Views 1 Watching
    • T Offline
      till.niese
      Hi. I have some troubles with the example code on GitHub - PluginCafe that shows how to create a Repository using Python.
      The code itself runs fine in R26 (R26.012 and R26.110), but results in an error in 2023.1.3.
      Did something change from R26 to 2023 how a repository has to be created using CreateRepositoryFromUrl or is that a problem with the python API? If it is a problem with the API is there a way around that?
      The code:
      def CreateRepositories():
          """Creates repositories for all user databases.
          Doing this is usually not necessary for performing light- to medium-sized asset operations, and
          the user preferences repository can then be used instead. Only when there is a substantial
          amount of assets that must be processed, a repository should be constructed to limit the
          search space for search operations. The method CreateRepositoryFromUrl() used in this example
          can also be used to create a repository and its underlying database from scratch when the
          provided URL points to location where no database has been established yet.
          # Wait for all asset databases to be loaded, abort when this is not possible.
          if not maxon.AssetDataBasesInterface.WaitForDatabaseLoading():
              return RuntimeError("Could not load asset databases.")
          # Get the default language of Cinema 4D (en-US) for retrieving the repository names.
          defaultLanguage = maxon.Resource.GetDefaultLanguage()
          # Iterate over all currently mounted databases and create an asset repository for each of them.
          # Doing this is usually not necessary as user asset databases are automatically part of the
          # the user preferences repository which is easier to retrieve. Creating a repository for a
          # specific user asset database can be useful to speed up asset searches.
          for database in maxon.AssetDataBasesInterface.GetDatabases():
              # Create a unique identifier for the repository.
              rid = maxon.AssetInterface.MakeUuid(str(database._dbUrl), True)
              # Repositories can be composed out of other repositories which are called bases. In this
              # case no bases are used to construct the repository. But with bases a repository for all
              # user databases could be constructed for example.
              bases = maxon.BaseArray(maxon.AssetRepositoryRef)
              # Create a writable and persistent repository for the database URL. If #_dbUrl would point
              # to a location where no database has been yet stored, the necessary data would be created.
              repository = maxon.AssetInterface.CreateRepositoryFromUrl(
                  rid, bases, database._dbUrl, True, False, False)
              if not repository:
                  raise RuntimeError("Repository construction failed.")
              # Access some properties of the newly created repository.
              repoId = repository.GetId()
              isWriteable = repository.IsWritable()
              name = repository.GetRepositoryName(defaultLanguage)
              print(f"{repository} ({name}): id - {repoId}, writeable: {isWriteable}")
      Error message I receive in C4D 2023:
      Traceback (most recent call last):
        File "scriptmanager", line 558, in <module>
        File "scriptmanager", line 234, in CreateRepositories
        File "C:\Program Files\Maxon Cinema 4D 2023\resource\modules\python\libs\python39\maxon\decorators.py", line 383, in Auto
          ExecStaticMethod(*args)
      TypeError: unable to convert builtins.NativePyData to @net.maxon.interface.class-cR
      • T Offline
        till.niese
        I just figured out that the API changed in 2023 from:
        static MAXON_METHOD Result<UpdatableAssetRepositoryRef> CreateRepositoryFromUrl(const Id& rid, const Block<const AssetRepositoryRef>& bases, const Url& url, Bool writable, Bool derivedInPrefs, Bool tempRepository);
        to:
        static MAXON_METHOD Result<UpdatableAssetRepositoryRef> CreateRepositoryFromUrl(const Id& rid, const Class<AssetRepositoryRef>& repoType, const Block<const AssetRepositoryRef>& bases, const Url& url, Bool writable, Bool derivedInPrefs, Bool tempRepository, const BackgroundEntryTuple& backgroundJob = {});
        In the c++ section of GitHub - PluginCafe there is an updated version:
        		maxon::UpdatableAssetRepositoryRef repository = maxon::AssetInterface::CreateRepositoryFromUrl(
        			uuid, maxon::AssetRepositoryTypes::AssetDatabase(), bases, database._dbUrl, true, true, true) iferr_return;
        I however don't know how to translate that to Python.
        In particular, what should I use for maxon::AssetRepositoryTypes::AssetDatabase(), and BackgroundEntryTuple?
          Hi @till-niese you are indeed right, the method was updated in C++ but not in Python although the dynamic handling of the python Maxon API make it possible to use it but the maxon.AssetRepositoryTypes.AssetDatabase was not exposed. I will fix it for the next version and properly make the BackgroundEntryTuple optional.
          In the meantime you can use the script bellow. GetRepositoryName also changed and is now taking 2 arguments.
          #coding: utf-8
          import maxon
          # The command id for the Asset Browser.
          CID_ASSET_BROWSER = 1054225
          @maxon.MAXON_REGISTRY("net.maxon.registry.assetrepositorytypes")
          class AssetRepositoryTypes(maxon.Registry):
              AssetDatabase = maxon.MAXON_DECLARATION("net.maxon.assets.repositorytype.database")
                  assetDb = AssetRepositoryTypes.AssetDatabase
                  assetDb = maxon.RegistryInterface.FindEntryValue(assetDb._registry, assetDb._ids)
                      rid, assetDb, bases, database._dbUrl, True, False, False, None)
                  if not repository:
                  name = repository.GetRepositoryName(defaultLanguage, True)
          • T Offline
            till.niese
            Hi @m_adam, this works perfectly. Thank you for your fast response.
