    Using AddCustomGui for primitive controls
    pythonr23
    4 Posts 5 Posters 1.1k Views 1 Watching
    • CairynC Offline
      Cairyn
      Hello;
      using AddCustomGui for complex controls like Quicktab or Linkbox seems easy enough, as you get a specific class derived from BaseCustomGui. However, in the description for GeDialog::AddCustomGui there are numerous "Symbol ID"s listed that do not have a specific class but result in a BaseCustomGui being returned: CUSTOMGUI_REAL, CUSTOMGUI_STATICTEXT, CUSTOMGUI_TIME, etc.
      Mostly they seem to correspond with certain primitives (which already have their own dedicated Add functions, e.g. CUSTOMGUI_REALSLIDER and AddEditSlider), but sometimes there is no separate Add function, as e.g. for CUSTOMGUI_PROGRESSBAR or CUSTOMGUI_MATRIX.
      I have no idea how to work with these.
      For complex controls, I just create the GUI:
      self.customcontrol = self.AddCustomGui(ID_CUSTOM, c4d.CUSTOMGUI_QUICKTAB,
      name="A quick tab",
      flags = c4d.BFH_SCALEFIT | c4d.BFV_FIT, minw=120, minh=30,
      customdata=bc)
      and work from there with the returned class. No issues here.
      If I try the same for a primitive control like CUSTOMGUI_REALSLIDER, no GUI appears in the dialog at all (the return value is BaseCustomGui, not None, so the call did not fail at least). I cannot find any documentation on parameters to be set through the passed BaseContainer, if that's the issue.
      You may say "use AddEditSlider" but there is no AddTime or AddProgressBar so I would expect AddCustomGui to work.
      I seem to overlook something important. What do these "Symbol ID"s document, and how do I use them?
        you have function to retrieve the custom datatype corresponding to the custom gui you are adding. But not all gadgets works the same.
        for CUSTOMGUI_PROGRESSBAR , you must send a message. DateTime you can either use the returned gadget or use FindCustomGui to update its data. CUSTOMGUI_QUICKTAB you can define the tabs in the CreateLayout function etc etc.
        as FindCustomData says:
        The method returns a BaseCustomGui when there is no class available for the custom GUI.
        This allows to interact with any custom GUI, calling for instance BaseCustomGui.GetData()/SetData().
        You can find this manual about the DateTime control/datatype.
        Some gadgets could be restricted to Description and looks bad or not work in a GeDialog.
        I wrote a plugin to test different cases and show how to use some gadgets.
        import collections
        import os
        from datetime import datetime
        # Be sure to use a unique ID obtained from www.plugincafe.com
        PLUGIN_ID = 9025250
        class MemoryViewerDialog(c4d.gui.GeDialog):
            def CreateLayout(self):
                This Method is called automatically when Cinema 4D Create the Layout (display) of the Dialog.
                self.GroupBegin(0, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 1)
                self.dateTimeControl = self.AddCustomGui(1000, c4d.DATETIME_GUI, name="date time",
                flags = c4d.BFH_SCALEFIT | c4d.BFV_FIT, minw=120, minh=30)
                quickTabGadgetBC = c4d.BaseContainer()
                quickTabGadgetBC.SetBool(c4d.QUICKTAB_SHOWSINGLE, True)
                quickTabGadgetBC.SetBool(c4d.QUICKTAB_NOMULTISELECT, False)
                self.quickTabGadget = self.AddCustomGui(1001, c4d.CUSTOMGUI_QUICKTAB, name="quick tab",
                flags = c4d.BFH_SCALEFIT | c4d.BFV_FIT, minw=120, minh=30, customdata = quickTabGadgetBC)
                self.quickTabGadget.AppendString(0, "First Tab", False)
                self.quickTabGadget.AppendString(0, "Second Tab Selected", True)
                self.AddButton(2000, c4d.BFH_SCALEFIT, 0, 0, "click me")
                self.progressBarGadget = self.AddCustomGui(1002, c4d.CUSTOMGUI_PROGRESSBAR, name="",
                self.GroupEnd()
            def Command(self, id, msg):
                print (id)
                if id == 2000:
                    timeDataType = self.FindCustomGui(1000, c4d.DATETIME_GUI)
                    print("this is timedata", timeDataType, self.dateTimeControl )
                    # Parse the time string
                    dt = datetime.strptime('16.07.2011 03:37:12',"%d.%m.%Y %H:%M:%S")
                    dtd = c4d.DateTimeData()
                    # Fills the Data object with the DateTime object
                    dtd.SetDateTime(dt)
                    timeDataType.SetDateTime(dtd, True, True)
                    progressMessage = c4d.BaseContainer(c4d.BFM_SETSTATUSBAR)
                    progressMessage.SetData(c4d.BFM_STATUSBAR_TXT , "this is displayed in the status bar")
                    self.SendMessage(1002, progressMessage)
        class MemoryViewerCommandData(c4d.plugins.CommandData):
            dialog = None
            def Execute(self, doc):
                Called when the user Execute the command (CallCommand or a clicks on the Command from the plugin menu)
                :param doc: the current active document
                :type doc: c4d.documents.BaseDocument
                :return: True if the command success
                # Creates the dialog if its not already exists
                if self.dialog is None:
                    self.dialog = MemoryViewerDialog()
                # Opens the dialog
                return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaulth=400, defaultw=400)
            def RestoreLayout(self, sec_ref):
                Used to restore an asynchronous dialog that has been placed in the users layout.
                :param sec_ref: The data that needs to be passed to the dlg (almost no use of it).
                :type sec_ref: PyCObject
                :return: True if the restore success
                # Restores the layout
                return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
            # Retrieves the icon path
            directory, _ = os.path.split(__file__)
            fn = os.path.join(directory, "res", "mviewer.tif")
            # Creates a BaseBitmap
            # Registers the Command plugin
            c4d.plugins.RegisterCommandPlugin(id=PLUGIN_ID,
                                              str="Py-MemoryViewer 2",
                                              help="Show the current mem usage of Cinema 4D.",
                                              info=0,
                                              dat=MemoryViewerCommandData(),
                                              icon=None)
        • CairynC Offline
          Cairyn @Manuel
          @manuel Thanks for the notes, there seems to be a lot that requires additional explanation beyond the API description. I may ask more specific questions later...
          Regarding the DateTime, I got a weird error when I try to show the extended GUI: the clock and calendar fields get duplicated:
          This happens upon calling
          self.dateTimeControl.SetLayoutMode(c4d.LAYOUTMODE_MAXIMIZED)
          or if you like the full script,
          from c4d import gui
          ID_BUTTON_CLOSE = 1001
          ID_DATETIME = 1002
          class CustomDialog(c4d.gui.GeDialog):
              def __init__(self):
                  self.customcontrol = None
                  self.SetTitle("Custom Control Test")
                  self.GroupBorderSpace(10, 10, 10, 10)
                  if self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT, cols=1, title="", groupflags=0):
                      bc = c4d.BaseContainer()
                      bc[c4d.DATETIME_TIME_CONTROL] = True
                      bc[c4d.DATETIME_DATE_CONTROL] = True
                      self.dateTimeControl = self.AddCustomGui(ID_DATETIME, c4d.DATETIME_GUI,
                              name="DateTime",
                              minw=10, minh=10, customdata=bc)
                      dtd.SetDateTime(dt)
                      self.dateTimeControl.SetDateTime(dtd)
                      self.GroupEnd()
                  if self.GroupBegin(id=0, flags=c4d.BFH_CENTER, cols=2, title="", groupflags=0):
                      self.GroupBorderSpace(0, 20, 0, 0)
                      self.AddButton(ID_BUTTON_CLOSE, c4d.BFH_SCALEFIT, name="Close")
                      self.GroupEnd()
              def Command(self, messageId, bc):
                  if messageId == ID_BUTTON_CLOSE:
                      self.Close()
              dlg = CustomDialog()
              dlg.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE)
              dt = dlg.dateTimeControl.GetDateTime().GetDateTime()
              print (dt.year, dt.month, dt.day)
              print (dt.hour, dt.minute, dt.second)
          (and no, it doesn't work in a CommandData plugin either...)
          I am still on R23.1 and have no current access to more recent versions, so this may actually be an error that has already been corrected, and it's no longer a valid question...
          • J Offline
            jana @Cairyn
            Hello @Cairyn ,
            without further questions or postings, we will consider this topic as solved by Friday 11th of august 2023 and flag it accordingly.
            Maxon SDK Group
