<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using AddCustomGui for primitive controls]]></title><description><![CDATA[<p dir="auto">Hello;<br />
using AddCustomGui for complex controls like Quicktab or Linkbox seems easy enough, as you get a specific class derived from BaseCustomGui. However, in the description for GeDialog::AddCustomGui there are numerous  "Symbol ID"s listed that do not have a specific class but result in a BaseCustomGui being returned: CUSTOMGUI_REAL, CUSTOMGUI_STATICTEXT, CUSTOMGUI_TIME, etc.</p>
<p dir="auto">Mostly they seem to correspond with certain primitives (which already have their own dedicated Add functions, e.g. CUSTOMGUI_REALSLIDER and AddEditSlider), but sometimes there is no separate Add function, as e.g. for CUSTOMGUI_PROGRESSBAR or CUSTOMGUI_MATRIX.</p>
<p dir="auto">I have no idea how to work with these.</p>
<p dir="auto">For complex controls, I just create the GUI:</p>
<pre><code>self.customcontrol = self.AddCustomGui(ID_CUSTOM, c4d.CUSTOMGUI_QUICKTAB,
name="A quick tab",
flags = c4d.BFH_SCALEFIT | c4d.BFV_FIT, minw=120, minh=30,
customdata=bc)
</code></pre>
<p dir="auto">and work from there with the returned class. No issues here.</p>
<p dir="auto">If I try the same for a primitive control like CUSTOMGUI_REALSLIDER, no GUI appears in the dialog at all (the return value is BaseCustomGui, not None, so the call did not fail at least). I cannot find any documentation on parameters to be set through the passed BaseContainer, if that's the issue.</p>
<p dir="auto">You may say "use AddEditSlider" but there is no AddTime or AddProgressBar so I would expect AddCustomGui to work.</p>
<p dir="auto">I seem to overlook something important. What do these "Symbol ID"s document, and how do I use them?</p>
]]></description><link>http://developers.maxon.net/forum/topic/14270/using-addcustomgui-for-primitive-controls</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 20:50:58 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/14270.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Nov 2022 22:44:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using AddCustomGui for primitive controls on Wed, 09 Aug 2023 05:19:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/cairyn">@<bdi>Cairyn</bdi></a> ,</p>
<p dir="auto">without further questions or postings, we will consider this topic as solved by Friday 11th of august 2023 and flag it accordingly.</p>
<p dir="auto">Thank you for your understanding,<br />
Maxon SDK Group</p>
]]></description><link>http://developers.maxon.net/forum/post/72197</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72197</guid><dc:creator><![CDATA[jana]]></dc:creator><pubDate>Wed, 09 Aug 2023 05:19:43 GMT</pubDate></item><item><title><![CDATA[Reply to Using AddCustomGui for primitive controls on Sun, 27 Nov 2022 11:14:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/manuel">@<bdi>manuel</bdi></a> Thanks for the notes, there seems to be a lot that requires additional explanation beyond the API description. I may ask more specific questions later...</p>
<p dir="auto">Regarding the DateTime, I got a weird error when I try to show the extended GUI: the clock and calendar fields get duplicated:</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1669547429216-20221124__05__screenshot_datetime_04.jpg" alt="20221124__05__Screenshot_DateTime_04.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">This happens upon calling</p>
<p dir="auto"><code>self.dateTimeControl.SetLayoutMode(c4d.LAYOUTMODE_MAXIMIZED)</code></p>
<p dir="auto">or if you like the full script,</p>
<pre><code>import c4d
from c4d import gui
from datetime import datetime
ID_BUTTON_CLOSE = 1001
ID_DATETIME = 1002
class CustomDialog(c4d.gui.GeDialog):
    def __init__(self):
        self.customcontrol = None
    def CreateLayout(self):
        self.SetTitle("Custom Control Test")
        self.GroupBorderSpace(10, 10, 10, 10)
        if self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT, cols=1, title="", groupflags=0):
            bc = c4d.BaseContainer()
            bc[c4d.DATETIME_TIME_CONTROL] = True
            bc[c4d.DATETIME_DATE_CONTROL] = True
            self.dateTimeControl = self.AddCustomGui(ID_DATETIME, c4d.DATETIME_GUI,
                    name="DateTime",
                    minw=10, minh=10, customdata=bc)
            dt = datetime.strptime('16.07.2011 03:37:12',"%d.%m.%Y %H:%M:%S")
            dtd = c4d.DateTimeData()
            dtd.SetDateTime(dt)
            self.dateTimeControl.SetDateTime(dtd)
            self.GroupEnd()
        if self.GroupBegin(id=0, flags=c4d.BFH_CENTER, cols=2, title="", groupflags=0):
            self.GroupBorderSpace(0, 20, 0, 0)
            self.AddButton(ID_BUTTON_CLOSE, c4d.BFH_SCALEFIT, name="Close")
            self.GroupEnd()
    def Command(self, messageId, bc):
        if messageId == ID_BUTTON_CLOSE:
            self.Close()
    dlg = CustomDialog()
    dlg.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE)
    dt = dlg.dateTimeControl.GetDateTime().GetDateTime()
    print (dt.year, dt.month, dt.day)
    print (dt.hour, dt.minute, dt.second)
if __name__=='__main__':
</code></pre>
<p dir="auto">(and no, it doesn't work in a CommandData plugin either...)<br />
I am still on R23.1 and have no current access to more recent versions, so this may actually be an error that has already been corrected, and it's no longer a valid question...</p>
]]></description><link>http://developers.maxon.net/forum/post/70234</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/70234</guid><dc:creator><![CDATA[Cairyn]]></dc:creator><pubDate>Sun, 27 Nov 2022 11:14:59 GMT</pubDate></item><item><title><![CDATA[Reply to Using AddCustomGui for primitive controls on Fri, 18 Nov 2022 17:04:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">you have function to retrieve the custom datatype corresponding to the custom gui you are adding. But not all gadgets works the same.</p>
<p dir="auto">for CUSTOMGUI_PROGRESSBAR , you must send a message. DateTime you can either use the returned gadget or use <a href="https://developers.maxon.net/docs/py/2023_2/modules/c4d.gui/GeDialog/index.html?highlight=findcustomgui#GeDialog.FindCustomGui" target="_blank" rel="noopener noreferrer nofollow ugc">FindCustomGui</a> to update its data. CUSTOMGUI_QUICKTAB you can define the tabs in the CreateLayout function etc etc.</p>
<p dir="auto">as FindCustomData says:</p>
<pre><code>The method returns a BaseCustomGui when there is no class available for the custom GUI.
This allows to interact with any custom GUI, calling for instance BaseCustomGui.GetData()/SetData().
</code></pre>
<p dir="auto">You can find <a href="https://developers.maxon.net/docs/cpp/2023_2/page_manual_customgui_datetime.html" target="_blank" rel="noopener noreferrer nofollow ugc">this manual</a> about the DateTime control/datatype.</p>
<p dir="auto">Some gadgets could be restricted to Description and looks bad or not work in a GeDialog.</p>
<p dir="auto">I wrote a plugin to test different cases and show how to use some gadgets.</p>
<pre><code>
import collections
import os
# Be sure to use a unique ID obtained from www.plugincafe.com
PLUGIN_ID = 9025250
class MemoryViewerDialog(c4d.gui.GeDialog):
        This Method is called automatically when Cinema 4D Create the Layout (display) of the Dialog.
        self.GroupBegin(0, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 1)
        self.dateTimeControl = self.AddCustomGui(1000, c4d.DATETIME_GUI, name="date time",
        flags = c4d.BFH_SCALEFIT | c4d.BFV_FIT, minw=120, minh=30)
        quickTabGadgetBC = c4d.BaseContainer()
        quickTabGadgetBC.SetBool(c4d.QUICKTAB_SHOWSINGLE, True)
        quickTabGadgetBC.SetBool(c4d.QUICKTAB_NOMULTISELECT, False)
        self.quickTabGadget = self.AddCustomGui(1001, c4d.CUSTOMGUI_QUICKTAB, name="quick tab",
        flags = c4d.BFH_SCALEFIT | c4d.BFV_FIT, minw=120, minh=30, customdata = quickTabGadgetBC)
        self.quickTabGadget.AppendString(0, "First Tab", False)
        self.quickTabGadget.AppendString(0, "Second Tab Selected", True)
        self.AddButton(2000, c4d.BFH_SCALEFIT, 0, 0, "click me")
        self.progressBarGadget = self.AddCustomGui(1002, c4d.CUSTOMGUI_PROGRESSBAR, name="",
        self.GroupEnd()
    def Command(self, id, msg):
        print (id)
        if id == 2000:
            timeDataType = self.FindCustomGui(1000, c4d.DATETIME_GUI)
            print("this is timedata", timeDataType, self.dateTimeControl )
            # Parse the time string
            # Fills the Data object with the DateTime object
            dtd.SetDateTime(dt)
            timeDataType.SetDateTime(dtd, True, True)
            progressMessage = c4d.BaseContainer(c4d.BFM_SETSTATUSBAR)
            progressMessage.SetData(c4d.BFM_STATUSBAR_TXT , "this is displayed in the status bar")
            self.SendMessage(1002, progressMessage)
class MemoryViewerCommandData(c4d.plugins.CommandData):
    dialog = None
    def Execute(self, doc):
        Called when the user Execute the command (CallCommand or a clicks on the Command from the plugin menu)
        :param doc: the current active document
        :type doc: c4d.documents.BaseDocument
        :return: True if the command success
        # Creates the dialog if its not already exists
        if self.dialog is None:
            self.dialog = MemoryViewerDialog()
        # Opens the dialog
        return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaulth=400, defaultw=400)
    def RestoreLayout(self, sec_ref):
        Used to restore an asynchronous dialog that has been placed in the users layout.
        :param sec_ref: The data that needs to be passed to the dlg (almost no use of it).
        :type sec_ref: PyCObject
        :return: True if the restore success
        # Restores the layout
        return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
    # Retrieves the icon path
    directory, _ = os.path.split(__file__)
    fn = os.path.join(directory, "res", "mviewer.tif")
    # Creates a BaseBitmap
    # Registers the Command plugin
    c4d.plugins.RegisterCommandPlugin(id=PLUGIN_ID,
                                      str="Py-MemoryViewer 2",
                                      help="Show the current mem usage of Cinema 4D.",
                                      info=0,
                                      dat=MemoryViewerCommandData(),
                                      icon=None)
</code></pre>
<p dir="auto">Cheers,<br />
Manuel</p>
]]></description><link>http://developers.maxon.net/forum/post/70217</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/70217</guid><dc:creator><![CDATA[Manuel]]></dc:creator><pubDate>Fri, 18 Nov 2022 17:04:21 GMT</pubDate></item></channel></rss>
