    Normal Move command has no effect in R2023
    3 Posts 2 Posters 1.2k Views 1 Watching
    • bacaB Offline
      baca
      Hi everyone,
      R2023 has issue with normal modeling commands, like Normal Move.
      R26, R25 and previous still working fine.
      For ex. this Python Generator has no effect over polygon objects:
      from typing import Optional
      doc: c4d.documents.BaseDocument # The document evaluating this python generator
      op: c4d.BaseObject # The python generator
      hh: Optional["PyCapsule"] # A HierarchyHelp object, only defined when main is executed
      def main() -> c4d.BaseObject:
          childOp = op.GetDown()
          cloneOp = (childOp.GetDeformCache() or childOp.GetCache() or childOp).GetClone()
          if cloneOp.CheckType(c4d.Opolygon):
              cloneOp.GetPolygonS().SelectAll(cloneOp.GetPolygonCount())
              bc = c4d.BaseContainer()
              bc.SetData(c4d.MDATA_NORMALMOVE_VALUE, 100.0)
              c4d.utils.SendModelingCommand(
                  command=c4d.ID_MODELING_NORMALMOVE_TOOL,
                  list=[cloneOp],
                  mode=c4d.MODELINGCOMMANDMODE_POLYGONSELECTION,
                  bc=bc,
                  doc=doc,
          childOp.Touch()
          return cloneOp
        Hi @baca you need to define the mode of the document to be in Mpolygons. I will check if this is really the intended way (tools being more context specific) or if this is a bug.
        So now you need to do something like that:
            doc = c4d.documents.BaseDocument()
            doc.SetMode(c4d.Mpolygons)
        Which give us:
                    list=[cloneOp],
                    bc=bc,
                    doc=doc,
            childOp.Touch()
            return cloneOp
        EDIT: After checking with the dev, this is indeed a bug we are going to fix, I added the "to fix" flag and will bump this topic once a fix will be available in a public release.
        bacaB 1 Reply Last reply Reply Quote 1
        • bacaB Offline
          baca @m_adam
          @m_adam thanks!
          • maxonM maxon moved this topic from Cinema 4D SDK on
