    Force VertexMap display
    18 Posts 3 Posters 6.0k Views 1 Watching
      ferdinand @rui_mac
      Hello Remo,
      Thank you for your updates,
      @rui_mac said in Force VertexMap display:
      Just implemented it but the problem is that when I turn the hidden tag active, the Attribute Manager tells me that there are two objects selected (Multiple Objects) and the parameters of my plugin tag are no longer displayed.
      Is there any way to keep both the hidden VertexMap tag and my plugin tag active, and display the parameters of my plugin tag in the Attribute Manager?
      I am not quite sure how you mean that, but I assume the underlying issue is here that I was not verbose enough in how at least I would implement that: You must constantly write from a source tag (or any other data source, does not have to be a vertex map) into a hidden vertex map and make sure that it stays selected.
      I do not have any problems implementing this, including having the plugin interface being shown in the Attribute Manger, or just generally poking around in the tag selection state of the object. Find a quick example below.
      If this was not what you meant, could you please restate what is going wrong for you? On a side note: We are exploiting here Cinema 4D behavior in an unintended manner, so this hack is not officially supported.
      The file:
      tag_shenenigans.c4d
      The result:
      The code:
      """Constantly copies over the data from a source vertex map to a hidden vertex map.
      This can be used to mimic manually drawing a vertex map. You could even extend this to draw the
      union, intersection, difference, etc. of multiple tags. This quick and dirty solution will not flood
      an object with dozens of tags by locking onto a unique ID on that hidden tag, but when the Python
      tag is removed, the hidden tag will linger. A more practical solution would be to implement this as a
      TagData plugin where one could clean up after oneself when the tag is being moved or deleted.
      import typing
      doc: c4d.documents.BaseDocument # The document evaluating this tag
      op: c4d.BaseTag # The Python scripting tag
      # An ID to identify a hidden vertex map tag that has been crated for the purpose of this Python
      # tag. We need this so that we can reestablish the linkage between this Python tag and a driver
      # without flooding a scene/object with these hidden drawing tags. The better solution would be to
      # bind the lifetime of such  drawing tag to the lifetime of a TagData plugin tag, but we cannot
      # do this here.
      ID_VM_DRAWTAG: int = 1060040
      def GetDrawTag(node: c4d.PolygonObject) -> typing.Tuple[c4d.VariableTag, c4d.VariableTag]:
          """Retrieves or creates the hidden drawing tag of a polygon object.
          # We loop over all tags on #node.
          tag: c4d.BaseTag = node.GetFirstTag()
          while isinstance(tag, c4d.BaseTag):
              # There usually will be at least two vertex map tags #node, the source and the hidden
              # drawing tag. We need a safe way to identify such hidden drawing tag which is ours.
              # For that we use C4DAtom.AddUniqueID/FindUniqueID to mark such tags via ID_VM_DRAWTAG as
              # ours.
              if tag.CheckType(c4d.Tvertexmap):
                  # Try to get the ID_VM_DRAWTAG UUID on a Tvertexmap tag.
                  mem: typing.Optional[memoryview] = tag.FindUniqueID(ID_VM_DRAWTAG)
                  # This overly cautious, but technically someone could have accidentally also written
                  # to that ID, so we check if the stored data is indeed #True. When this is the case,
                  # we have found the draw tag and return it.
                  if isinstance(mem, memoryview):
                      data: bytes = bytes(mem)
                      try:
                          if bool(data) == True:
                              return tag
                      except:
                          print ("Stepping over unexpected UUID data.")
              # Continue tag iteration on #node.
              tag = tag.GetNext()
          # When we have reached this line, it means there is no #ID_VM_DRAWTAG Tvertexmap tag on #node.
          # We create a new tag with the size of node, hide the tag and insert it under #node and then
          # return that new tag.
          tag: c4d.VariableTag = c4d.VariableTag(c4d.Tvertexmap, node.GetPointCount())
          if not isinstance(tag, c4d.BaseTag):
              raise MemoryError("Could not allocate vertex map tag.")
          tag.AddUniqueID(ID_VM_DRAWTAG, bytes(True))
          tag.ChangeNBit(c4d.NBIT_OHIDE, True)
          node.InsertTag(tag)
          return tag
          """Called by Cinema 4D to execute the Python tag.
          # Get the data source vertex map from the user data. Again, this code is a bit overly cautious,
          # and expects the user data access to fail.
          try:
              sourceTag: c4d.VariableTag = op[c4d.ID_USERDATA, 1]
              if (not isinstance(sourceTag, c4d.VariableTag)) or (sourceTag.GetType() != c4d.Tvertexmap):
          except:
          # Get the polygon object the Python tag is attached to.
          node: c4d.PolygonObject = op.GetMain()
          if not isinstance(node, c4d.PolygonObject):
          # Create or get the hidden "DrawTag" and bail when the source and draw tag do not match in size.
          drawTag: c4d.VariableTag = GetDrawTag(node)
          if sourceTag.GetDataCount() != drawTag.GetDataCount():
          # Copy the data and make sure the hidden drawing tag is still selected.
          drawTag.SetAllHighlevelData(sourceTag.GetAllHighlevelData())
          drawTag.SetBit(c4d.BIT_ACTIVE)
      R 1 Reply Last reply Reply Quote 0
      • R Offline
        rui_mac @ferdinand
        @ferdinand,
        When I tried to implement this, as soon as I do the tag.ChangeNBit(c4d.NBIT_OHIDE, True) thing, the Attribute Manager changes to show the attributes of the VertexMap tag, and the parameters of my plugin tag, that create the hidden VertexMap tag disapear.
        I'm at work now, but I will recheck my code agaisnt yours, later.
        Thank you so much.
          ferdinand @rui_mac
          @rui_mac
          You should not do this on an already inserted tag, the code I am showing above is as lined out very much in a grey area, or to be a bit more blunt, is a giant threading restriction violation. You should refrain from modifying the scene graph from outside of the main thread as much as you can, as this can introduce everything between odd behavior to outright crashes.
          But I would say the singular insertion of the vertex map tag is somewhat safe. When you run into problems, you must defer all scene graph modifications, i.e., the insertion of that hidden tag, to the main thread. By for example using NodeData::Message to carry out something that before has been lined up by TagData::Execute.
          • R Offline
            rui_mac
            I was creating the hidden VertexMap in the Init method of my plugin tag.
            But my main problem, like I described, was that activating the hidden VertexMap tag would show the VertexMap parameters in the Attribute Manager, instead of the parameters of my plugin tag.
              ferdinand @rui_mac
              Hey @rui_mac,
              I assume you mean here that the tag node was made the "active object" of the Attribute Manager, i.e., it had the same effect as if you called c4d.gui.ActiveObjectManager_SetObject on the hidden tag? This could be a side-effect of 'misbehaving' in a threaded environment, I assume you are in TagData::Execute, but it seems unlikely. Could you please share an executable example of your code, because otherwise it will be very hard for me to help you.
              • R Offline
                rui_mac @ferdinand
                @ferdinand, here is a version of my code with all the stuff that is not important for this problem, removed. Although, I fully commented everything I removed.
                I hope it is enough to spot the problem.
                import os
                import sys
                import math
                import random
                from c4d import gui,plugins,bitmaps,documents,utils,Matrix,BaseContainer
                from c4d import threading
                PLUGIN_ID = 1037312
                CHECK_ID = 1037275
                PLUGIN_NAME ="VertexMapMix"
                PLUGIN_VERSION = "1.1"
                url_access	= "vertexmapmix"
                # define the IDs of the interface elements
                VMM_ONOFF = 1000
                VMM_VERTEXMAP = 1001
                VMM_ATOMS = 1002
                VMM_CREATEVERTEXTAG = 1003
                VMM_SELECTVERTEXTAG = 1004
                VMM_ATOM_ONOFF = 2001
                VMM_ATOM_MIX = 2002
                VMM_ATOM_INVERT = 2003
                VMM_ATOM_SELECT = 2004
                VMM_ATOM_NAME = 2005
                VMM_ATOM_OPACITY = 2006
                VMM_ATOM_BLUR = 2007
                VMM_REMAPPING = 2020
                VMM_ATOM_CURVE = 2021
                VMM_SHOW = 2025
                VMM_MIX_NORMAL = 0
                VMM_MIX_MULT = 1
                VMM_MIX_MIN = 2
                VMM_MIX_MAX = 3
                VMM_MIX_ADD = 4
                VMM_MIX_SUB = 5
                icon_edit = c4d.bitmaps.BaseBitmap()
                class vertex_mm(plugins.TagData):
                	old_selection	= 0
                	old_pressed		= -1
                	old_show 		= 1
                	def Init(self,node):
                		# in here I initialize all the GUI elements
                		# and in here I create the hidden VertexMap tag
                		op = node.GetMain()
                    	if not isinstance(op, c4d.PolygonObject): return True
                			tags = op.GetTags()
                			hidden_tag = None
                			for tag in tags:
                				if tag[c4d.ID_BASELIST_NAME] == "vmm_hidden":
                					hidden_tag = tag
                					break
                			if hidden_tag == None:
                				pnum=op.GetPointCount()
                				hidden_tag=c4d.VariableTag(c4d.Tvertexmap,pnum)
                				op.InsertTag(hidden_tag)
                				hidden_tag[c4d.ID_BASELIST_NAME]="vmm_hidden"
                				hidden_tag.ChangeNBit(c4d.NBIT_OHIDE,True)
                	def Message(self,node,type,data):
                		if node==None: return True
                		# this code would turn the display of the VertexMap values on or off,
                		# depending on the state of a checkbok
                		if type==c4d.MSG_DESCRIPTION_VALIDATE:
                			state =  node[VMM_SHOW]
                			if state != self.old_show:
                				self.old_show = state
                				op = node.GetObject()
                				if op.GetType() != 5100: return True
                				tags = op.GetTags()
                				hidden_tag = None
                				for tag in tags:
                						hidden_tag = tag
                						break
                				if state == 1:
                					hidden_tag.SetBit(c4d.BIT_ACTIVE)
                					op.SetBit(c4d.BIT_ACTIVE)
                					op.Message(c4d.MSG_UPDATE)
                					hidden_tag.DelBit(c4d.BIT_ACTIVE)
                	def Execute(self,tag,doc,op,bt,priority,flags):
                		# here I do all the stuff that the plugin is supposed to do
                		# at the end, in the list called w_array1, are all the values
                		# to store in the hidden VertexMap tag, for display
                		tags = op.GetTags()
                		hidden_tag = None
                		for tag in tags:
                				hidden_tag = tag
                				break
                		if hidden_tag != None:
                			hidden_tag.SetAllHighlevelData(w_array1)
                		vertex_mix.SetAllHighlevelData(w_array1)
                		# the "vertex_mix" is a visible VertexMap tag, where the values are also stored.
                		# IMPORTANT!!!
                		# if it would be possible to make the VertexMap shading appear, simply by using
                		# this visible VertexMap tag, I would be more than fine with this.
                		# The problem, so far, is that I have to click this visible tag to make the
                		# shading appear, and that makes all the parameters of my plugin Tag disapear
                		# from the Attribute Manager.
                		return c4d.EXECUTIONRESULT_OK
                # registration of the tag
                if __name__=="__main__":
                # Register the Tag
                	icon = c4d.bitmaps.BaseBitmap()
                	icon.InitWith(os.path.join(dir, "res", "icon_vmm.tif"))
                	icon_edit.InitWith(os.path.join(dir, "res", "edit.tif"))
                	c4d.gui.RegisterIcon(1037349,icon_edit)
                	plugins.RegisterTagPlugin(id=PLUGIN_ID, str=PLUGIN_NAME, g=vertex_mm,
                						 description="vertexmapmix", icon=icon,
                						 info=c4d.TAG_EXPRESSION|c4d.TAG_VISIBLE|c4d.TAG_MULTIPLE)
                	print("["+PLUGIN_NAME+" Tag - v"+PLUGIN_VERSION+"] by Rui Batista: Loaded")
                ferdinandF 2 Replies Last reply Reply Quote 0
                  ferdinand @rui_mac
                  Hello @rui_mac,
                  I will have a look tomorrow; I was busy today.
                    ferdinand @rui_mac
                    Hello @rui_mac,
                    So, I had a look at your code. It was unfortunately not executable in this form, even when I filled in some gaps like adding the necessary resources or re-indenting stuff. So, I cannot say many concrete things here, and only look at the general form.
                    I must also point out again, that this is a hack and not officially supported. If you chose to take this route instead of drawing the data yourself, possible side effects will be up to you to handle.
                    • A general thing is that you seem to assume that Message, Init, and other methods to always run on the main thread. But there is no guarantee for that; when you want to carry out actions only allowed on the main thread, you must still check for being on the main thread. I however still think that adding a tag from a non-main thread was not your issue here.
                    • This line in your Init is dangerous and might be the source for your problems, as you forcibly select the host object of your tag: op.SetBit(c4d.BIT_ACTIVE)
                    • In general, you are also very generous with Message(c4d.MSG_UPDATE) calls. They are first of all here unnecessary for the flag changes and secondly also dangerous. I would never send messages to a node which is already part of the scene graph from threaded environment (you call op.Message(c4d.MSG_UPDATE) in multiple contexts).
                    • Using the name of a node is a poor way of identifying a node, you should use UUIDs in Python.
                    • I have provided below a TagData solution for your problem. This is quite a bit of busy work, especially when you want to properly clean up after yourself. This works fine for me.
                    if it would be possible to make the VertexMap shading appear, simply by using this visible VertexMap tag, I would be more than fine with this.
                    It would be the same, just iterate over the tags of the node hosting your tag and select whatever tags you want to select.
                    The result:
                    The plugin: pc14184.zip
                    The pyp file of the plugin:
                    """Implements a tag which manages a hidden vertex map to draw data.
                    import typing
                    class VertexMapMixData(c4d.plugins.TagData):
                        PLUGIN_ID: int = 1037312
                        DRAWTAG_ID: int = 1060040
                        PLUGIN_NAME: str = "VertexMapMix"
                        PLUGIN_DESCRIPTION: str = "Tvertexmapmix"
                        def __init__(self) -> None:
                            """Initializes the instance, specifically its _hiddenDrawTags lookup table.
                            self._hiddenDrawTags: dict[bytes: c4d.BaseTag] = {}
                            super().__init__()
                        def FlushHiddenTags(self, node: c4d.GeListNode) -> None:
                            """Flushes the #_hiddenDrawTags cache and removes all the hidden tags from the hosting node.
                            host: typing.Optional[c4d.BaseObject] = node.GetMain()
                            if not isinstance(host, c4d.BaseObject):
                            tag: c4d.BaseTag
                            for tag in host.GetTags():
                                if tag.GetType() != c4d.Tvertexmap:
                                    continue
                                # This is a hidden drawing tag instance.
                                uuid: typing.Optional[memoryview] = tag.FindUniqueID(VertexMapMixData.DRAWTAG_ID)
                                if isinstance(uuid, memoryview):
                                    tag.Remove()
                            self._hiddenDrawTags = {}
                        def GetHiddenDrawTag(self, node: c4d.PolygonObject) -> typing.Optional[c4d.VariableTag]:
                            """Retrieves the hidden drawing tag on a polygon object.
                            # Bail when #node is not a polygon object or not attached to a document.
                            if (not isinstance(node, c4d.PolygonObject) or
                                    not isinstance(node.GetDocument(), c4d.documents.BaseDocument)):
                                return None
                            # Get the UUID of the polygon object so that we look up its hidden tag in the lookup.
                            uuid: typing.Optional[memoryview] = node.FindUniqueID(c4d.MAXON_CREATOR_ID)
                            if not isinstance(uuid, memoryview):
                                return None
                            # Check if there is already a cached hidden draw tag in dictionary of the plugin interface.
                            hiddenTag: typing.Optional[c4d.BaseTag] = self._hiddenDrawTags.get(bytes(uuid), None)
                            if isinstance(hiddenTag, c4d.BaseTag) and hiddenTag.IsAlive():
                                return hiddenTag
                            # Just for verbosity here to make clear that this can still return None.
                            return None
                        def SetHiddenDrawTag(self, node: c4d.BaseTag) -> None:
                            """Creates the hidden drawing tag on a polygon object.
                            # The host is not a polygon object or there is already a valid drawing tag on that host.
                                    isinstance(self.GetHiddenDrawTag(node), c4d.VariableTag)):
                            # Flush the cache to remove any lingering tags and get the UUID of the polygon object so
                            # that we cache the hidden draw tags.
                            self.FlushHiddenTags(node)
                            hostUuid: typing.Optional[memoryview] = node.FindUniqueID(c4d.MAXON_CREATOR_ID)
                            if not isinstance(hostUuid, memoryview):
                            # Start creating the new tag, for that we must be on the main thread.
                            if not c4d.threading.GeIsMainThread():
                            tag.AddUniqueID(VertexMapMixData.DRAWTAG_ID, bytes(True))
                            node.InsertTag(tag)
                            # Put the tag in the lookup table.
                            self._hiddenDrawTags[bytes(hostUuid)] = tag
                        def Init(self, node: c4d.GeListNode) -> bool:
                            """Called by Cinema 4D to initialize the node.
                            self.InitAttr(node, c4d.BaseList2D, c4d.ID_SOURCE_DATA)
                            self.InitAttr(node, bool, c4d.ID_DRAW_DATA)
                            node[c4d.ID_SOURCE_DATA] = None
                            node[c4d.ID_DRAW_DATA] = True
                            # Attempt to create the tag, as all methods, Init is not guaranteed to be on the main thread.
                            self.SetHiddenDrawTag(node.GetMain())
                        def Free(self, node: c4d.GeListNode) -> None:
                            """Called by Cinema 4D when the node is about to be destroyed.
                            Will remove all hidden tags on the node.
                        def CopyTo(self, dest: c4d.plugins.NodeData, snode: c4d.GeListNode, dnode: c4d.GeListNode,
                                   flags: int, trn: c4d.AliasTrans) -> bool:
                            """Called by Cinema 4D when a tag is being copied.
                            Will remove all hidden tags on the source node, so that when a user drag-and_drops the tag
                            from object A to object B, object A is being cleaned up.
                            self.FlushHiddenTags(snode)
                        def Message(self, node: c4d.GeListNode, type: int, data: object) -> bool:
                            """Called by Cinema 4D to send messages to the node.
                            We just use this here as something that is called often on the main thread. But there is
                            no guarantee that this will run on the main thread, you were sending yourself a message,
                            MSG_UPDATE, to a node outside of the main thread in your TagData::Execute. Never assume
                            Message to run on the main thread only.
                            # Try to create the tag, could be throttled by picking a specific message ID which is
                            # called often enough.
                        def Execute(self, tag: c4d.BaseTag, doc: c4d.documents.BaseDocument, op: c4d.BaseObject,
                                    bt: c4d.threading.BaseThread, priority: int, flags: int) -> int:
                            """Called by Cinema 4D to execute the tag.
                            state: bool = tag[c4d.ID_DRAW_DATA]
                            src: typing.Optional[c4d.VariableTag] = tag[c4d.ID_SOURCE_DATA]
                            dst: typing.Optional[c4d.VariableTag] = self.GetHiddenDrawTag(op)
                            # There is no source or destination tag we could write from or to.
                            if not isinstance(src, c4d.VariableTag) or not isinstance(dst, c4d.VariableTag):
                            # Select or deselect the hidden tag.
                            if tag[c4d.ID_DRAW_DATA]:
                                dst.SetBit(c4d.BIT_ACTIVE)
                                dst.DelBit(c4d.BIT_ACTIVE)
                            # Determine of we should copy the data and then copy the data.
                            if (src.GetType() != dst.GetType() or
                                    src.GetDataCount() != dst.GetDataCount()):
                            dst.SetAllHighlevelData(src.GetAllHighlevelData())
                    def RegisterPlugin() -> None:
                        """Registers the plugin.
                        if not c4d.plugins.RegisterTagPlugin(
                                id=VertexMapMixData.PLUGIN_ID,
                                str=VertexMapMixData.PLUGIN_NAME,
                                g=VertexMapMixData,
                                description=VertexMapMixData.PLUGIN_DESCRIPTION,
                                icon=c4d.bitmaps.InitResourceBitmap(c4d.FLgradient),
                                info=c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE | c4d.TAG_MULTIPLE):
                            raise RuntimeError(f"Failed to register: {VertexMapMixData}")
                        RegisterPlugin()
                    • R Offline
                      rui_mac @ferdinand
                      @ferdinand, thank you for the excellent advices.
                      I hope I can get home soon enough after work to clean up my code according to your advices and implement your solution.
                      Also, your advices will allow me to clean up some of my other plugins.
                      Thank you very much, once again.
                      • R Offline
                        rui_mac
                        Well, it kind of works. When I adjust parameters in the plugin tag, sometimes the Attribute Manager reverts to show "2 Elements [VertexMap,ThePluginName]"
                        I even tried with your plugin and, by twirling the Data Source parameter open and, for example, turning the Invert option on, the Attribute Manager stops showing the plugin parameters, and starts showing "2 Elements [VertexMap,VertexMapMax]"
                          ferdinand @rui_mac
                          Hello @rui_mac,
                          ah, okay, I understand what you mean. Yeah, that is a bit odd and also makes this solution not very viable. As I said before, this always was a hack. When I did this myself a few years ago, I think I never ran into this issue.
                          The underlying problem here is that the Attribute Manager is able to display a hidden tag as selected and the whole setup relies on the fact that hidden tags are being ignored in that context. It is also very erratic how this happens, when I for example click long enough on the Draw Data bool, the problem will also occur at some point and at the same time, it sometimes it does not happen 'inside' the vertexmap when I change a parameter there.
                          Since this seems to be tied to parameter writing events, you could try to switch off the hidden tag being selected before a parameter is being written and turn it back on after that. But that will become really complicated or even possible to do for 'buried' parameters changes, such as for example, changing something in a field driving a vertex map which is linked in the tag.
                          I will file this as a bug because the Attribute Manager should not be able to display hidden tags in single or multi-selections. In the meantime, I can only recommend using C++ and drawing things yourself or using CustomDataTagDisplayInterface, as this will be performant and is also guaranteed to work.
                          • R Offline
                            rui_mac @ferdinand
                            @ferdinand, thank you for the answer and explanation. I will try to find a compromise.
                            In the meanwhile, one can always select the tag, lock the Attribute Manager and click the VertexMap tag to display the result. Cumbersome, but it works.
                            • ymoonY Offline
                              ymoon
                              @ferdinand, Is it possible to VertexColor, WeightMap(character rig) in the same way?
                              Some games use VertexColor, so marking can always be useful.
                              I tried to convert your code to VertexColor, but I lack knowledge. Please help us.
