    how to Scroll UserArea
    s22python
    7 Posts 2 Posters 1.9k Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      In my scrollgroup, I created a UserArea to draw pictures, but the size of the pictures to be drawn is dynamic,
      that is to say, when the dialog is opened, different pictures are loaded and switching displayed by clicking button . When image size changing, expect the scrolling gui component to always be correct.
      (The picture drawn in the UserArea is 1:1, such as a 1280 * 720 picture file, the size in UserArea drawed also 1280 * 720).
      When I created it, the size of the UserArea could not automatically adapt to the image size, which caused the gui component of the scroll group to not work as expected.
      After reading these two posts(Scrolling in UA/Scaling a GeUserArea in a ScrollGroup), I still can't achieve this goal! Thanks for any help!
      相信我,可以的!
        chuanzhen
        This is the sample code, I tried to dynamically create the element inside the group to achieve, the picture is not drawn completely as expected:
        import os
        import sys
        from c4d import gui,bitmaps,plugins,utils,modules,storage
        PLUGIN_ID = 10000000 #only for test
        GROUP_SCROLL = 1100
        USEEAREA_GROUP = 1102
        USERAREA = 1101
        ADD_BUTTON = 1200
        class PreViewArea(gui.GeUserArea):
            bmp = None
            def DrawMsg(self,x1, y1, x2, y2, msg):
                self.OffScreenOn()
                self.SetClippingRegion(x1, y1, x2, y2)
                BG_colorDict = self.GetColorRGB(c4d.COLOR_BG)
                BG_color = c4d.Vector(BG_colorDict['r'], BG_colorDict['g'], BG_colorDict['b']) / 255.0
                self.DrawSetPen(BG_color)
                if self.bmp:
                    width = self.bmp.GetBw()
                    height = self.bmp.GetBh()
                    self.DrawBitmap(self.bmp, 0, 0, width, height, 0, 0, width, height, c4d.BMP_NORMAL)
        def dynamic_Group(dialog,ua):
            dialog.LayoutFlushGroup(USEEAREA_GROUP)
            if ua.bmp:
                width = ua.bmp.GetBw()
                height = ua.bmp.GetBh()
                width,height = 0,0
            dialog.AddUserArea(USERAREA, c4d.BFH_SCALE | c4d.BFV_SCALE,width,height)
            dialog.AttachUserArea(ua, USERAREA)
            dialog.LayoutChanged(USEEAREA_GROUP)
        class S_Lib_Dialog(gui.GeDialog):
            ua = PreViewArea()
            def CreateLayout(self):
                self.SetTitle("test")
                self.ScrollGroupBegin(PLUGIN_ID, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, c4d.SCROLLGROUP_HORIZ | c4d.SCROLLGROUP_VERT)
                self.GroupBegin(USEEAREA_GROUP,c4d.BFH_LEFT | c4d.BFV_TOP,1,1)
                self.GroupBorder(c4d.BORDER_ACTIVE_1)
                self.AddUserArea(USERAREA, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT)
                self.AttachUserArea(self.ua, USERAREA)
                self.GroupEnd()
                self.GroupEnd()
                self.AddButton(ADD_BUTTON,c4d.BFH_SCALEFIT,150,30,"Load image")
            def Command(self, id, msg):
                if id == ADD_BUTTON:
                    path = storage.LoadDialog(type=c4d.FILESELECTTYPE_IMAGES)
                    if path:
                        bmp = bitmaps.BaseBitmap()
                        result,ismovie = bmp.InitWith(path)
                        if result == c4d.IMAGERESULT_OK:
                            self.ua.bmp = bmp
                            dynamic_Group(self, self.ua)
                            self.ua.Redraw()
                            print("Load image Fail")
                        print("Not select image")
        class S_Lib(plugins.CommandData):
            dialog = None
            def Execute(self,doc):
                # create the dialog
                if self.dialog is None:
                    self.dialog = S_Lib_Dialog()
                return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=800, defaulth=400)
            def RestoreLayout(self, sec_ref):
                # manage nonmodal dialog
                return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
        # Execute main()
            path, fn = os.path.split(__file__)
            plugins.RegisterCommandPlugin(id=PLUGIN_ID,
                                          str="test",
                                          info=0,
                                          help="",
                                          dat=S_Lib(),
                                          icon=None)
        相信我,可以的!
          Hi @chuanzhen just to let you know I'm a bit busy with the release but I will look into it today or tomorrow. Thanks a lot for your code-sample this help a lot.
          chuanzhenC 1 Reply Last reply Reply Quote 0
            chuanzhen @m_adam
            @m_adam Thanks!
            相信我,可以的!
              Hi @chuanzhen just to let know I was able to reproduce your issue, but still not able to find a correct workaround with the time I had today, I will have a deeper look at it Monday and this will be my top priority 🙂
                Hi @chuanzhen you have to override the GetMinSize in order to notify the Dialog about the size of your GeUserArea, the issue I had is that I overlooked to update the value within your dynamic_Group method so it was not working properly.
                So here you adopted code that works properly
                import os
                import sys
                from c4d import gui, bitmaps, plugins, utils, modules, storage
                PLUGIN_ID = 10000000  # only for test
                GROUP_SCROLL = 1100
                USERAREA = 1101
                ADD_BUTTON = 1200
                    def __init__(self):
                        self.bmp = None
                        self.width = 0
                        self.height = 0
                    def DrawMsg(self, x1, y1, x2, y2, msg):
                        self.OffScreenOn()
                        if self.bmp:
                            self.width = self.bmp.GetBw()
                            self.height = self.bmp.GetBh()
                            self.DrawBitmap(self.bmp, 0, 0, self.width, self.height, 0, 0, self.width, self.height, c4d.BMP_NORMAL)
                    def GetMinSize(self):
                        return self.width, self.height
                def dynamic_Group(dialog, ua):
                    if ua.bmp:
                        ua.width = ua.bmp.GetBw()
                        ua.height = ua.bmp.GetBh()
                        ua.width, ua.height = 0, 0
                    dialog.AddUserArea(USERAREA, c4d.BFH_SCALE | c4d.BFV_SCALE, ua.width, ua.height)
                    def __init__(self):
                        self.ua = PreViewArea()
                        self.GroupBegin(USEEAREA_GROUP, c4d.BFH_LEFT | c4d.BFV_TOP, 0, 0)
                        self.GroupEnd()
                        self.GroupEnd()
                        self.AddButton(ADD_BUTTON, c4d.BFH_SCALEFIT, 150, 30, "Load image")
                            if path:
                                result, ismovie = bmp.InitWith(path)
                                    self.ua.bmp = bmp
                                    self.ua.Redraw()
                    dialog = None
                    def Execute(self, doc):
                        # create the dialog
                # Execute main()
                                                  str="test",
                                                  info=0,
                                                  help="",
                                                  dat=S_Lib(),
                                                  icon=None)
                As a side note I would advice you to use member variable bound to instance and not directly to the class itself.
                  chuanzhen @m_adam
                  @m_adam Thanks for your help,great work!
                  相信我,可以的!
