    Take Manager not recording Material Tag changes when running Python script
    3 Posts 3 Posters 1.0k Views 2 Watching
    • C Offline
      cinamatic
      The Python code below creates a new take, then finds the object of interest in order to add a new material tag for the newly created take (only). The code adds the material tag, however it does not record the changes within the Take Manager under take named "TEST". Any idea what the issue might be ?
      # Main function
          doc.StartUndo()
          c4d.CallCommand(431000081) # Auto Take toggle on
          # Create needed take system variables
          take_data = doc.GetTakeData()
          main_take = take_data.GetMainTake()
          child_take = main_take.GetDown()
          if child_take is None:
              msg = "Create first child take to clone. Only one take should be present in the take manager at this time"
              raise RuntimeError(msg)
          # Create a new take & set it as active
          new_take = take_data.AddTake("", main_take, child_take)
          new_take.SetName("TEST")
          take_data.SetCurrentTake(new_take)
          # Find object of interest and create an empty material tag
          obj = doc.SearchObject('Body') # Find object
          tag = obj.MakeTag(c4d.Ttexture) # Create an empty Materials Tag within object
          # Find material and assign it to the tag
          mat = doc.SearchMaterial('Fine') # Find material within Material Manager
          tag.SetMaterial(mat) # Assign material to tag associated with object
          #tag[c4d.TEXTURETAG_MATERIAL]=mat #alternate code, not needed
          # Take Manager is not reflecting changes from above to the currently active take "TEST".
          #tag.AddTag(take_data,c4d.Ttexture,mat) # something I tried to solve this issue, however didn't work
          doc.AddUndo(c4d.UNDOTYPE_NEW,tag)
          doc.EndUndo()
      # Execute main()
        depending on what you want to do, there are different solutions.
        You may want to add the material tag on a specific take and the object could have no material tag by default. This is done using OverrideGroups.
        The other way would be to create the tag and modify the value of the material field, but it is not the way it should be done
        You can also find some usefull information about takes and material on this thread
        # Main function
            doc.StartUndo()
            if new_take is None:
                raise ValueError("Could not create a new take")
            if mat is None:
                raise ValueError("Could not find the material")
            if obj is None:
                raise ValueError("Could not find the Object")
            overrideGroup = new_take.AddOverrideGroup()
            if overrideGroup is None:
                raise ValueError("could not create the override Group")
            # Create the material tag for that group and assign the material to it
            overrideGroup.AddTag(take_data, c4d.Ttexture, mat)
            # Do not forget to add the object to the group
            overrideGroup.AddToGroup(take_data, obj)
            doc.EndUndo()
        # Execute main()
          Hello @cinamatic,
          without any further questions or other postings, we will consider this topic as solved and flag it as such by Friday, 17/06/2022.
