    StringToNumber to BaseTime
    6 Posts 3 Posters 730 Views 3 Watching
    • mikeudinM Offline
      mikeudin
      Hi guys!
      Is it possible to convert string value to BaseTime with this function?
      Converts a string to a data value of type float, int or c4d.BaseTime.
      >>> c4d.utils.StringToNumber('11', c4d.FORMAT_FRAMES, doc.GetFps())
      11.0
      >>> c4d.utils.StringToNumber('11', c4d.FORMAT_SECONDS, doc.GetFps())
      11.0
      >>> c4d.utils.StringToNumber(11, c4d.FORMAT_FRAMES, doc.GetFps())
      11.0
      After some tests i had no luck with it.😬🤷‍♂️
      >>> doc[c4d.DOCUMENT_MINTIME] = c4d.utils.StringToNumber('11', c4d.FORMAT_FRAMES, doc.GetFps())
      Traceback (most recent call last):
        File "console", line 1, in <module>
      TypeError: __setitem__ expected c4d.BaseTime, not float
      Thank you!
      https://mikeudin.net
        ferdinand @mikeudin
        Hello @mikeudin,
        thank you for reaching out to us. I had a look at the C++ backend and the statement you quoted does not seem to be true (anymore). The cases FORMAT_FRAMES, FORMAT_SECONDS and FORMAT_SMPTE all return a float value. So, both the Python and C++ documentation are not correct. I will add a task to fix these issues.
        It is not 100% clear to me what you were trying to achieve, but I think this is what you want to do:
        >>> import c4d
        >>> value = "11"
        # This call does not make much sense IMHO. One could just use int() or float()
        # to convert a frame value expressed by a string into a numeric value.
        11.0
        >>> int(value)
        11
        # Convert a frame-value to a value in seconds for a given document. A BaseTime value is
        # document independent, a value in frames is not, we must provide the FPS.
        >>> t = int(value) / doc.GetFps()
        >>> doc.GetFps()
        30
        >>> t
        0.36666666666666664
        # Pack the value into a BaseTime
        >>> bt = c4d.BaseTime(t)
        >>> bt
        <c4d.BaseTime object at 0x000001C2B9D3E6C0>
        >>> bt.Get()
        0.367
        • fwilleke80F Offline
          fwilleke80
          If you simply want to set the document's min time, why not just do this:
          doc[c4d.DOCUMENT_MINTIME] = c4d.BaseTime(11)
          www.frankwilleke.de
            If you simply want to set the document's min time, why not just do this ...
            Well, the question is what that value is supposed to be. Judging from the context I assumed it to be a value in frames and not seconds. Your BaseTime would be equal to frame 330 for a document with 30 FPS. And also, the input is meant to be a string.
              fwilleke80
              Oh, ok. I assumed he just wanted to set the document min time and didn't know a better way to get a BaseTime than using StringToNumber.
              www.frankwilleke.de
              • mikeudinM Offline
                mikeudin
                Great, thank you guys!
