    R21 c4dpy LoadFile always return False
    sdkpython
    6 Posts 2 Posters 1.2k Views 1 Watching
    • S Offline
      sol87
      What I was doing is just open a c4d file via python. The file is so simple as there is only a cube.
      It works in C4D Console,
      But not working in c4dpy.
      Am I missing something? Pls give me a hint.
        ferdinand @sol87
        Hello @sol87,
        Welcome to the Plugin Café and thank you for reaching out to us.
        What you are encountering is intended behavior. LoadFile is intrinsically bound to the GUI of Cinema 4D, e.g., calling it on a bitmap will open the Picture Viewer, calling it on a c4d file will scene into the editor. c4dpy is basically a GUIless Cinema 4D instance governed by a Python interpreter, which makes certain operations impossible (everything that requires a GUI).
        LoadDocument should however work fine in c4dpy as it does not try to load the scene into the editor.
        • S Offline
          sol87
          Hi @ferdinand ,
          Thx so much for your help. But I still I still haven't succeeded to load the file.
          I tried LoadDocument method like this, but it returns None.
          >>> d = documents.LoadDocument(
                  'test.c4d',
                  c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS | c4d.SCENEFILTER_MERGESCENE,
                  thread=None)
          >>> print(d)
          None
          Am I using the loadflags in wrong way?
          • S Offline
            sol87
            What I'm actually doing is making a python script to load render settings such as frame range, resolutions, cameras should be rendered from c4d files.
            Is there any shortcut to figure it out?
              ferdinand @sol87
              Hey @sol87,
              it works fine for me here. You are using a relative file path though, which is not supported by these loading functions.
              S 1 Reply Last reply Reply Quote 1
              • S Offline
                sol87 @ferdinand
                wow, awesome. It works!
                thank you so much.
